So I have this image which is 5312 pixels in width and 2988 pixels in height. I need to create a banner ad in this ratio: 300x250.
So this is what I do:
1) Create a new Photoshop document in this ratio 300x250.
2) Drag the 5312x2988 picture into the Photoshop document. The picture when comes perfectly fitted into the white box, but I can see the quality is wayyyyy lower. I still need it a little bit smaller though.
3) Hold shift and then make it a little bit smaller and then the quality gets even worse.
Can anyone help me out how I should open this picture in this banned ad ratio in perfect quality Should be possible in 2018 right?
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
Does this help? It looks better at 100%, but when I go at websites where they also use this ad ratio it's not like 100% view. So I zoom in till it looks like the ads on the website and it looks not as HD as the original.
Is the ad supposed to be 300px by 250px or not?
If a browser displays the image bigger (maybe in order to compensate the display size for a high resolution display) then that is not Photoshop’s doing.
Yes the ad should be 300x250. I think it's not the problem you are saying. What I tried to say was that at 100% view it looks clean, but it's not good.
Open the document, not drag. Save as PSD with new name. Then use Image > Image size to Resize. There are quality options. Results may not be better but try it.
If the image has the intended pixel dimensions and looks OK in Photoshop at View > 100% then the problem is not within Photoshop.
Please post a screenshot of the image as displayed in the browser.
hmmm..interesting. So the view at 100% is how it will also look when I post the ad on my desktop browser? I will try it later and then upload the result. I thought I had to zoom in till the ad box with the picture gets evenly big as the ad box on the browsers. Which is around 150%.
Again: If the browser upsamples images then Photoshop has no influence on that.
Maybe you have to address the issue with responsive image content and multiple versions of the image.
i HAVEN'T UNDERSTAND EVERYTHING YOU SAID , BUT i DO UNDERSTAND THAT WHAT i SEE AT 100% IS WHAT I WILL GET SO THANKS MAN. HAVE DONE 2 OTHER ADS WITH OTHER RATIOS AND WILL MAKE THE 300X250 ALSO ONE TIME AND IF I HAVE TROUBLE I WILL MAKE A POST ABOUT IT. I THINK YOU ANSWERED MY QUESTIONS THO.
I dont't get it. So I should open the picture of the mug in a photoshop document and then save that as a psd file. Then I should open that psd file as a document...but then I have the picture in a psd file lol. I need it in the 300x250 ad document
Save as a PSD file to protect your original file. Always save PSD for later editing. Never edit JPEG twice!! Of course export JPEG to deliver.
