Just recently when I make a selection and add a layer mask my selected image turns transparent. For the image attached I used Color Range to make selection and when I add the layer mask it comes out looking like this. The same thing happens if I try to make a selection using Channels. I did change my mask layer display options to black and 100% opacity in Channels. I can't find anything on the wonderfully vast internet to fix this issue. Any help is greatly appreciated.
It looks like Select color range has partially selected the color of the wanted area. Do you get the same issue with a simple lasso selection with no feather?
For a simple smooth edged shape like that I would use the pen tool to create a path then use the path to make the mask
Dave
Can you please include the open layers panel in you screenshot?
~Barb
Layer masks are black and white and shades of gray. Black hides the pixels on that layer, white shows them, and all the grays in between offer partial transparency. There are grays in that mask, which is why we can see through the couch.
~Barb
Thanks for your help, Barb. I guess it's back to the trusty ol' pen tool.
You could try a Levels adjustment on the layer mask to get rid of the transparency.
Just move the Highlights slider to the left.
Image>Adjustments>Levels
Mask with some transparency
After moving the Highlights slider to the left
Dave
Hmmm, well that makes sense. No, when I use the pen tool, lasso tool, or magic wand and then apply a layer mask the image stays at 100% opacity. I just noticed this happening the last couple of projects and didn't know if I accidentally hit something I wasn't supposed to. Thanks for your help!
