After installing the lastest version of Premiere Pro CC, now I get an error when I use the Dip to White transition effect.
Can anybody help me??
There were fixes made to Dip to Black/White transitions in the 12.1.2 update (just released) that should address this issue.
More information on fixed issues and new functionality:
I had the same problem. Now after choosing my export settings again, on the bottom there is the "use previews" box, I checked it this time and it seems to be working.
Dip to white seems to working just fine here on windows.
Using previews is only usefull if the export codec is the same as the preview codec.
I would disagree with that. I think using previews is only justified if the preview codec is of sufficient quality. You'd not want to use MPEG2 previews (the most common option) for exporting, even when exporting to MPEG2.
On the other hand, using Cineform previews when exporting to H.264 is fine.
I have the same problem and I stock in exporting my footage with dip to white effects
Many issues occur since adobe start updating premiere
any =ones know how to resolve the issue
Hi KilakDiseño,
Dip to White has been reengineered for this version. Is this a new project or an updated one? If it's the latter, I can see why you might be having trouble. Try again in a brand new project and see if it works for you.
Kevin
Hi thanks for the reply
that was the last one
the problem still the same. however, I realised that when I remove my audio
file some of the errors will be gone and there is less crash but my video
does not have audio
Sorry about that. Be sure to file your issues with us here: Premiere Pro: Hot (883 ideas) – Adobe video & audio apps
Kevin
I have the same problem, with old and new projects,
it's driving me crazy !
Please Adobe Staff, help us !
Would it be possible to supply us with your Project and files that will reproduce this issue?
Thank you.
For those experiencing this issue, we have found a reproducible case and wanted to verify if this is what you are also doing. We are investigating an issue where the Renderer is set to Mercury Playback Engine Software Only and Maximum Bit Depth is checked. e.g.:
1) Go to File menu > Project Settings > General > Video Rendering and Playback > set Renderer: to Mercury Playback Engine Software Only. Click OK.
2) Add Dip to White or Dip to Black Transition to a file in the Timeline Sequence.
3) In Sequence Settings or Export Settings, check the checkbox for Maximum Bit Depth/Render at Maximum Depth.
4) Render preview or Export Media.
Please let us know if this is also what you are doing or if you have a different case to reproduce.
Possible workarounds are to set Renderer: to CUDA or OpenCL or Metal (Mac). If you need to use Renderer: Software Only, you could try unchecking Maximum Bit Depth.
Yes these are the same settings I am using but still have trouble exporting, the dip to black transition being the error
I have no option to select CUDA or OpenCL as the renderer so still looking for a fix for this on windows.
Please can you help with this fix, hoping to get this project exported asap.
Ryan
If your Renderer: is set to Mercury Playback Engine Software Only, then select your Sequence tab in the Timeline, then go to Sequence menu > Sequence Settings and uncheck Maximum Bit Depth. Save and Quit. Relaunch Premiere.
Select your Sequence and bring up the Export Settings, select the Video tab and uncheck Render at Maximum Bit Depth. Does your export now complete without issue?
Yes those settings worked, thanks very much.
Ryan
Glad to hear this worked for you. Thank you.
I had the same low-level exception issue, but with Dip to Black. I unchecked "Render at Maximum Bit Depth" and then it was happy. No more error. This error occurred in Premiere Pro CC version 12.1.1 on Windows 10. Then updated to the latest version, went back and exported the same sequence with "Render at Maximum Bit Depth" turned back on, and yeah looks like Adobe fixed it.
