Hi people!
I was working on my Macbook pro, on Lightroom Classic CC 7.0.1 and using Color Filters on my pictures (Like green, for example), and everything was pretty cool.
Then I need to open the same Catalog ( all the files it's on my external hd) in another Macbook (on Lightroom Classic CC 7.0.1 Also!) and all the "Color Filters" that I did, were missing!
So I try to make some new color filters on this new computer and for my surprise, when I return to the first Macbook/Lightroom it doesn't see them also
BTW, Star Rating Filter is working pretty fine!
Anyone has any idea what is happening?!
Thank you a lot!
As I am on a trip with only my iPad, I can't show you a screenshot. But here are the instructions: How to flag, label, and rate photos in Lightroom Classic CC
It's probably just a matter of choosing the same preset on the second computer in 'Metadata - Color Label Set'
If you need to edit a set, scroll down almost to the bottom of the page:
You can assign names to color labels in the Edit Color Label Set dialog box. The name is then added to the photo’s metadata when you apply
...Copy link to clipboard
Check the menu for the labels. The names of the labels need to be exactly the same on both computers, because that is how color labels are stored. So if a red label is called 'Red' on one computer, but 'HDR' on the other for example, then the red labels will not carry over.
It might be just a matter of changing the label preset on the second computer.
First of all, thank you for your reply!
An then,... sorry for the dummie question, but, how can I change the "Color Labels" name?
Isn't it an Adobe default setting?
I do found on Lightroom Preferences how to change main Language of LR, but the Color Labels still in the older language (Portuguese).
What I am doing wrong?!
Thanks in advance!
You can assign names to color labels in the Edit Color Label Set dialog box. The name is then added to the photo’s metadata when you apply the label.
Thank you so much!
It helped me a lot!
Now, everything is working fine on both computers!
You Rock!
