I have added a skin called 'Ice' under Skins on the Project
tab. I can preview it under 'View' but the skin hasn't applied to
my project. I checked in my folders, and the 'Ice' files are in the
!SkinSubFolder!. What am I missing? I'm using RoboHelp HTML X5.0.2.
Thanks for any help!
Peggy
If you're generating WebHelp or FlashHelp, you select the
skin on the first page of the single source layout dialog. Then
generate, and the skin should appear.
In addition to what Ben advised, if you are viewing locally
from IE, it's possible that the IE ActiveX warning (Yellow
Information Bar) is popping up and preventing things from working
too. In that case you may need to either click through some dialogs
in IE or adjust some IE settings to always see things properly.
Thanks for your instant replies--what service!
However, I need to generate HTML help, and there is no field
to select the skin when I go to generate the CHM file. And I
haven't seen any ActiveX warnings.
Skins don't apply to HTML Help. You can customize HTML Help a
little by going to Windows in your Project Manager, creating a new
window, and working with the settings there. Then, when you
generate your HTML Help, you select that skin. Make sure that HTML
Help is designated as your primary layout when you go to make the
window so that RH knows the window applies to that layout.
