I'm running InDesign CC 13.1 (latest version) on Windows 10, and I'm trying to create check boxes on an interactive map that our staff will use to track progress as they complete various training courses.
I have successfully set up two variations of the check boxes -- one that is just a checkbox overlaid above the map marker graphic, and one using some map marker graphics I created. I have set up all six appearance states for both of the check box options.
When I export to PDF, they work great — until I click away from them. Then the checkbox field resets with a huge check mark filling the clickable space. This happens in both Acrobat DC Reader and Pro apps. Here are some screen shots:
Overlay version (where checkbox field is just sitting on top of the underlying map marker):
Initial view:
Clicked:
After click-away:
Custom version (where the states are linked versions of the marker graphic and I've deleted the check mark from all states):
Initial view:
As you can see, the marker is missing for some reason.
How it is supposed to look in the initial view:
Clicked:
After click-away:
Am I doing something wrong? I followed the steps exactly as I've seen them repeated in several places online, and I can't figure out why the appearance is resetting like this. I feel like there's an inactive state beyond the 6 states that needs to be set (or something like that...).
Thanks in advance for your help!
JN
Hi
About the missing marker (custom version), hard to tell without seeing your Buttons and forms panel, with all states... maybe you could share a screenshot?
About the "giant tick" issue, here's my guess:
(pasted from Re: InDesign checkbox appearance in Acrobat )
"I believe you are talking about the (annoying) "Highlight existing fields" Acrobat (reader/pro) feature. You can turn it off in Acrobat, but be aware this is an application setting, not a document one.
So, even if the PDF is displayed fine
...Copy link to clipboard
Hi
So, even if the PDF is displayed fine for you, this feature might be turned on in any other user application.
Now, here comes the trick: you can use a small JavaScript code in order to turn it off by default while opening the PDF.
In Acrobat Pro, go Tools > JavaScript > Document JavaScripts, create a new Script (name it as you wish), click add and replace the existing bit by: app.runtimeHighlight = false;
Click OK and you should be done."
Note: default color for highlighting fields is light blue but it can be changed through preferences
Here's an animated illustration of your replicated issue:
(Mettre les champs existants en surbrillance = Highlight existing fields)
Hope that helps
Vinny
vinny38 wrote
… Now, here comes the trick: you can use a small JavaScript code in order to turn it off by default while opening the PDF.In Acrobat Pro, go Tools > JavaScript > Document JavaScripts, create a new Script (name it as you wish), click add and replace the existing bit by:
Hi Vinny,
for that to work—also an application setting, no document setting—the customer has to turn on JavaScript in the Reader. And only Adobe Acrobat Reader on Windows or Mac OS X will be able to work with JavaScript for PDF, I think.
Uwe
This totally fixed the issue, THANK YOU!
(PS: The animated walkthrough was really helpful — I sincerely appreciate the time you put into your response!)
