Global change tables
Feb 12, 2008 Feb 12, 2008
There are lots of tables in my manuals, all of which are set to be transparent. I realized that they look better when the table borders are solid black, so i would like to change all of them and there are loads! is there a way to do a global change rather than individually changing each table's properties?
Pete
328
Hi Pete.
RH does have find and replace tool but for this type of thing I'd recommend you use a tool use as FAR this allows you to find HTML spread over several lines of Truecode. You'll have to do a bit of investigative work to find the best code to use but with some thought it is possible. You may also find that the your table code may be different across tables even though they look the same. Don't forget to take a backup so you can revert back if you need to.
A recent quick test indicates that with RH7 you can specify the borders from the CSS stylesheet. That did not override existing inline colours but that should not be an issue for you.
I cannot guarantee it will work for your tables and it might be necessary to go to each table and apply a table class. There's probably a way of doing that using a find and replace tool.
It depends on your knowledge of CSS and confidence in undertaking multi file find and replace operations.
Whatever you do, make a backup first. Unless of course you want to be looking for a new job!
wow thanks for the awesome response! i will have a play around but im scared as im not too confident <makes backup>
thanks
RoboHelp Documentation
Download Adobe RoboHelp
