Photoshop CS6 can't open CR2 Pictures from Canon G7X. Worse I can't converted them to DNG. I downloaded the last version but it didn't change the problem. (grey circle or pale in the list). Thank you for help
When you point to the source files for the dng converter, just point to the folder, not the cr2 files inside.
Is this the (Powershot) G7 X Mark II? The G7 X had support under Camera Raw 8.7 but the G7 X Mark II had support under Camera Raw 9.6. Photoshop CS6's Camera Raw support ended at 9.1.1.
That still doesn't explain why the DNG Converter won't work (as it should). I'm assuming you're using DNG Converter 10.3?
Digital Negative (DNG), Adobe DNG Converter | Adobe Photoshop CC
Yes !
Envoyé de mon iPad
Le 6 avr. 2018 à 20:35, Warunicorn <forums_noreply@adobe.com> a écrit :
DNG converter refuses CR2
created by Warunicorn in Photoshop - View the full discussion
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/10298157#10298157 and clicking ‘Correct’ below the answer
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/10298157#10298157
To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
Start a new discussion in Photoshop by email or at Adobe Community
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
This email was sent by Adobe Community because you are a registered user.
You may unsubscribe instantly from Adobe Community, or adjust email frequency in your email preferences
You went through the steps for using the Converter?
I did as usual. It’s not the first time I use the converter. Now there is a change since the last time. Before I used a low cost cable to download the pictures that didn’t work after a few times. I then bought a Canon cable. With the lost cost one there was no problem !!
Envoyé de mon iPad
Yesssssss !!! Fine. Thank you so much ♡
created by Jeff Arola <https://forums.adobe.com/people/Jeff+Arola> in Photoshop - View the full discussion <https://forums.adobe.com/message/10298748#10298748>
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/10298748#10298748 and clicking ‘Correct’ below the answer
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/10298748#10298748
Start a new discussion in Photoshop by email <mailto:discussions-community-photoshop@adobe-v8.hosted.jivesoftware.com> or at Adobe Community <https://forums.adobe.com/choose-container.jspa?contentType=1&containerType=14&container=4694>
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624 <https://forums.adobe.com/thread/1516624>.
You may unsubscribe <https://forums.adobe.com/unsubscribe.jspa?email=veronique5%40mac.com&token=f64a3d4185f3daae8c991a9f392cc536e37f488482238a522c1945e0af0bbe96> instantly from Adobe Community, or adjust email frequency in your email preferences <https://forums.adobe.com/user-preferences!input.jspa>
Check this out: Can't open raw files in CS6
also, Google "can't open cr2 files in photoshop cs6"
Hello, I have OS10.14 running Photoshop CS6. It wouldn't open CR2 files so I downloaded the DNG converter (v9.1.1). I point to a folder to convert but after spinning for awhile, it says the Converter can't open CR2 files. My camera is a Canon T7i (800D).
You need at least dng converter 9.10 or newer.
9.1.1 is an older version.
The dng converter 12.1 should work:
