How do I create a crawl title after the update? The simple title option is gone. I will not vent my frustrations with this, but I do need help.
I had not looked at the Essential Graphics Panel ROLL option, which was new with the Oct 2017 (12.0.0) release. I add screenshots here of the two roll options.
[Edited to make it clear it was the Roll option that was added with 12.0.0.]
Legacy title
Essential Graphics Panel with a graphic selected in the timeline. Once the Roll is checked, the other options appear.
My preferred method is to create the title in Photoshop and keyframe it's animation in PP.
OK, I've never had to do that before, but I'll figure it out.
How do I preform your suggestion?
It's a pretty simple two step process.
1. Create the title in Photoshop.
2. Keyframe the title's Position in Premiere Pro.
You don't know how to do either of those things?
Creating the titles are not the problem making them continuously move is the issue.
For Harold's suggestion (the one I think you are looking for), once you create a legacy title, you select the motion option (in the title panel) and select "roll" (the options being "still," "roll," "crawl left," and "crawl right").
For Jim's suggestion (the method I prefer), he has pointed you to the keyframes instructions - you keyframe motion to move the titles as you wish.
Hey bro, Thank you! I was overlooking that option. SMH
It's also pretty easy to make rolls in the new EGP. There's a click-command spot in that panel for it.
Neil
Legacy title
you must use LEGACY TITTLE
OK, And then?
These "tips" create a roll graphic, not a crawl. If Legacy Titles (GraphicS) wasn't broken, why fix it?
Hi Felix,
I believe the Legacy Titler code is incompatible with the current version. The announcement to move away from Legacy Titler was a long time ago. Sorry about that. I would create a text string and keyframe the Position parameter. Can you try that?
Kevin
Vent, CODShow, because it didn't make sense to do away with something that worked and did so well. This "help" page creates rolls and not crawls.
