Does anyone have any idea why all of a sudden I'm getting a periodic pop-up window whenever I open/print a PDF? The pop-up says:
"AdobeResourceSynchronizer wants to use your confidential information stored in 'v3.services.acrobat.com' in your keychain. Do you want to allow access to this item?"
The options are either Always Allow, Deny, or Allow. I have been clicking Deny every time (screw this!), but it keeps popping up. Can I remove this f-ing thing from my Mac altogether??
I have Acrobat Pro with the monthly subscription, and I'm running OSX Version 10.11.6.
TIA.
Hi Kristaj,
As per the description above, you want to disable the Adobe Resource Synchronizer which is popping up while opening/printing any PDF, Is that correct?
Please try the steps from the following link: https://answers.acrobatusers.com/I-m-getting-every-half-an-hour-the-reguest-from-AdobeResourceSynchronizer-It-wants-to-use-my-keychain-servicesa-q8523.aspx
You may also refer to the thread: How to disable AdobeResourceSynchronizer?
Let us know, how it goes.
Anand Sri.
Hi Kristaj,
Please try the steps from the following link: https://answers.acrobatusers.com/I-m-getting-every-half-an-hour-the-reguest-from-AdobeResourceSynchr...
Anand Sri.
Thank you! I was able to disable it (I think).
Have tried removing it but still pop up when open a pdf file.
Hi Janet Fung,
Please follow the instruction from the following thread: How to disable AdobeResourceSynchronizer?
Hope this helps.
Anand Sri.
bobs82410472
I too have seen this a maddening number of times over the past month. I have REMOVED it from my system as suggested twice only to have it start again after several days. I am close to removing the entire product if I can find another product that will accomplish similar use. This program is supposed to be a tool for me to use in my course of business responsibility. Denying this access 40-60 times a day when using this program is unacceptable.
On a Mac: Go to System Preferences. Click on Users & Groups. Click on your user name. Click on tab that says Login Items. Uncheck Adobe Synchronizer. Click on lock to save changes. Done.
I believe that clicking on the item only hides it. if you want to remove it from automatically loading when you log in, you must click on the minus sign at the bottom of the box while the item is highlighted.
Hi Bobs,
We apologize for the inconvenience caused to you.
Please try the steps from the following link: https://answers.acrobatusers.com/I-m-getting-every-half-an-hour-the-reguest-from-AdobeReso urceSynch...
Hope this helps, and keep us posted with the results.
Anand Sri.
Tried the suggested fix and it works for a short while then goes back to the pop up. I was hoping most recent update would address this but didn't.
Hello bobs82410472
Sorry for the delay in response to your query and apologize for the inconvenience caused.As you mentioned that you downloaded the latest updates but it did not fix the issue. Please try to repair the installation files of Acrobat or Reader installed from Help menu>Repair installation(only for Windows)
Restart the computer once and check if this brings any difference.
If the issue persists, please share the following details:
Let us know how it goes.
Anand Sri.
Adobe Pro.
Mac system.
Bob Slechta
[perosnal info removed by moderator: email and phone number]
Have tried every suggestion - nothing works. Pop-up continues every time I open a PDF doc. Can't even find Adobe Resource Syncronizer on my iMac (OS 10.13.1), using Firefox Quantum (v57).
Hello Kronmanaj,
We apologize for the inconvenience caused. Please try the steps from the following link: https://answers.acrobatusers.com/I-m-getting-every-half-an-hour-the-reguest-from-AdobeReso urceSynch...
You may also refer to the thread: https://forums.adobe.com/thread/822790
Check for the latest update of Acrobat/Reader Help>Check for updates. You can also download the updates manually through Overview — Acrobat and Adobe Reader Release Notes Link: http://www.adobe.com/devnet-docs/acrobatetk/tools/ReleaseNotes/index.html
Once the updates are installed, restart the computer.
Hope this helps, and let us know how it goes.
Anand Sri.
I am having the same problem with this pop-up. I've tried removing from activity monitor and users but it just reappears - v frustrating
Hello peterg75661941
Sorry for the delay in response to your query and apologize for the inconvenience caused. Please check for the latest updates from Help menu>Check for updates.
You may also download the latest updates manually from Overview — Acrobat and Adobe Reader Release Notes
Anand Sri.
This not addressed to me.
Bob Slechta
Hello Bob,
We apologize for the inconvenience, please use the Acrobat cleaner tool to remove the Acrobat once Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Restart the machine and install the Acrobat Pro from Download Pro or Standard versions of Acrobat DC, 2017, XI, or X
Anand Sri.
Have tried everything in this forum and it keeps coming back. Using Acrobat Pro XI; only started doing this after I gave the DC a tryout. DUmped that app, and the problem will not go away.
I guess Adobe's not supporting XI anymore?
You're right, peterpica. Either acting with compliance to their strategy as they officially make it clear or after reading these forums (or even this thread and the threads alike) they pulled their PDF services for Acrobat 11 downwards lately. I had the confirmation on their part having contacted Adobe Care Support on Twitter. They told that as soon as an Acrobat product had been discontinuted so had been the PDF services. and advised me to go with the manual way. It sucks but I guess we have no choice from now on.
Just another reason to abandon Adobe. Switching to Quark 1st. Too bad.
from... Peter StremicPETERPICA Productionswww.peterpica.competer@peterpica.com215.961.7979Daily: 10-12, 1-4 & 7-9Weekends: Pot luck"If it's not worth doing well, it's not worth doing at all."
Whatever happened to the customary 7 years of support for software releases?
I am utterly frustrated by this ridiculous bug. Before answering, would the support person PLEASE VERIFY THAT THE PROPOSED SOLUTION ACTUALLY WORKS so that this issue can be closed. The only other option is to permanently remove all of the Adobe junk from my machines and buy a product that works.
I am in complete agreement.
Has the solution described by Anand Sri. worked for anyone?
I am really weary of going ahed with this woithout confirmation tha it indeed removes the:""AdobeResourceSynchronizer wants to use your confidential information stored in 'v3.services.acrobat.com' in your keychain. Do you want to allow access to this item?" problem.
Fabio
