Hello everyone.
I am trying to fill selected areas on a zip code map to easily ID what staff members cover what areas. The map is a PDF from Philadelphia PA (
Just another note, if you do use the pen tool and the fill as you're drawing the shape, the shape often obscures what you're trying to trace, so reduce the opacity of the new layer once you start drawing.
Are you using the pen tool using the shape option? You should be able to fill the shape and change it whenever you want.
Pen tool – yes
Shape option – uh…no. Didn’t know it could do that.
See the options bar when using the pen tool
Dave
