1
The CSS Properties panel does not open in Fireworks CS6.
Dec 27, 2017 Dec 27, 2017
The CSS Properties panel does not open, neither with the menu nor with the keyboard shortcut Ctrl + F7, this functionality is not executed. I use Windows 10 Pro.
How can I solve that.
Thank you.
1.4K
Community Expert , Sep 17, 2018 Sep 17, 2018
Here is a registry hack to get the disabled panels working in Fireworks CS6 :
Navigate to: HKEY_CURRENT_USER\Software\Adobe\CSXS.3
Create a string value with name "PlayerDebugMode" and value: 1
Restart Fireworks if it was already open.
I found this solution on Facebook here:  https://www.facebook.com/groups/fwsingapore/  credit to Martin Karachorov
Jan 12, 2018 Jan 12, 2018
Same problem! I use windows10 X64 LTSB, fireworks cs6 can't view css propertis panel,
and when I open Adobe Extension Manager CS6, It says many .zxp files in "C:\ProgramData\Adobe\Fireworks CS6\PreInstall" are failed to import.
Someone please help, thank you!
Apr 09, 2018 Apr 09, 2018
Auch das selbe Problem (CS6) die Palette CSS_Eigenschaften öffnet sich nicht - ist das so wie bei der Minibridge einfach von Adobe disabled? Komplett gekauft und irgendwann ist nichts mehr da
Aug 25, 2018 Aug 25, 2018
Is there a solution to this or has the css panel been removed/disabled in Fireworks ??
Paul-M - Community Expert
Aug 26, 2018 Aug 26, 2018
The issue appears to be that all extensions bundled with Fireworks CS6 have been signed with the same certificate which has expired
Temp workaround and hardly ideal at all
1) Launch Fireworks
2) Turn your system clock back a few years
3) Launch the CSS Properties Panel
BTW XD is NOT a viable replacement for Fireworks, its not even close.
Anybody got a permanent a better fix ??
