hello, i did fresh installed of the lightroom cc on my mac, then i copy the preset from my mac desktop to the macbook, then i realised the preset wont show up. so i check the folder link it was correct.
turns out the preset contains ~ symbol infront that caused this problem because i did try to remove the symbol in one preset and it show up right away on the preset.
is there any way to fix it without rename it?
OS Macbook : High sierra
OS Mac : Sierra
When Lightroom Classic updates from 7.2 to 7.3 it converts all .LRTEMPLATE preset files to .XMP files in a new folder {Settings}.
It also leaves the .LRTEMPLATE preset files with the tilde '~' prefix added to the file name so that 7.3 does not convert the presets a second time.
If you are copying Presets between two computers both running v7.3 then copy the .XMP versions in the {Settings} folder.
(or remove the Tilde by renaming and Copy and Paste to the 'old' folder location {Develop Presets} whe
...Copy link to clipboard
The tilde is a reserved character in Mac OS X as in most Unix systems and it stands for the location of the user's home directory. Similar to characters like the slash "/", "?", and "*" and such they can cause all kinds of problems even though Finder itself seems to have no problems with them. You shouldn't use these in filenames.
I didnt rename or name this file. It’s automatically set by the imac. I just copy the whole folder and transfer it to my macbook. Weirdly that imac can recognised the preset. How did that happened to high sierra (macbook pro) if the problem here caused by the OS
(or remove the Tilde by renaming and Copy and Paste to the 'old' folder location {Develop Presets} where they will be converted.)
thank you so much! its working now!!
so if i moving the presets, i need to copy the XML now since the current presets contain tilde prefix?
Yes. The v7.3 .XMP preset files in their new location
No. The "OLD" v7.2 .LRTEMPLATE presets contain tilde prefix?
Thanks WobertC! I had forgotten about the automatic .xmp conversion!
