I use Acrobat Pro DC on a PC.
I have never been able to use the 'redo' key command (control shift z?). Nothing happens.
Does anyone know how to enable/make it work?
Redo means "reverse the last Undo". Nothing else. You are looking for a "repeat last action" function, but there is not one of these.
What specific action did you just Undo, and did you do anything after the Undo?
It is redo rather than undo.
So, for instance, I will select then highlight a piece of text. I will then select another piece of text, and try and use the redo key command to highlight that. But, nothing happens, and i have to right-click and then choose highlight from the drop-down menu.
Ah! That explains it! Thank you!
It would be really helpful to have a repeat function!!
thanks again
