Hi, I'm using the Huion GT220v2 and I have this bug where everytime I do a vertical brush stroke, the brush is replcaced by the hand tool automatically. I tried to uncheck the windows ink and then it works but there's no pen pressure.
How can I fix this please??? I've been trying to solve this for the last 3 hours (reinstalling the driver, restarting, chaning preferences, editing the pen flicks, uncheck and re-checking the windows ink checkbox) and nothing works!
Did someone ran accross this problem and solved it maybe? I saw some threads about it here but some are un-answered or have answers that didn't solve my problem.
Specs:
Windows 10 Pro
version: 1709
OS Build: 16299.371
Huion driver version: 13.15.16.180104
Hello, simply apply this update that fixes this problem, among others: https://helpx.adobe.com/photoshop/kb/cannot-paint-with-stylus-when-zoomed-in-windows-10.html
Hi
It sounds like you have the same issue being experienced by Wacom users.
The latest windows update (KB4093112) has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following (recommended) :
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the tablet properties and uncheck "Use Windows Ink"
4. Restart Photoshop
That is it - all should now work well (you need to do all the above steps to retain pen pressure)
Note : There is a third option. Microsoft made this change intentionally and they have issued a way round it with registry change (see link below). However for Photoshop the PSUserConfig method works.
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
Dave
I just used the text file method you mentioned and it totally worked. Can't thank you enough, Dave!
doesn't again!
now the brush doesn't work at all. What else can I do?
Thank you
