Hello all,
I've spent an hour looking through the forums here and haven't found a solution to my problem. I have two simple PNG image sequences (with transparency) I'm looking to layer over single layers of video. This has always been super simple in the past, but all of a sudden I'm having inexplicable problems.
Here is what I'm seeing (both in the timeline and in the export):
Password: hooper
For your information, the BIG HOOPER logo is one PNG sequence, but the little "H" bug in the lower right is a completely different image sequence in a different folder. I have no idea why it is blending them. They are in no way touching or on the same video channel or anything. It's like my computer doesn't know which image sequence it is looking at.
For reference, here is my folder structure. The HooperBug is the little "H" and the HooperLogo is the big logo. They should not be blending, flashing, or anything.
Thank you in advance for your help! Obviously this is a client job and I'm very confused.
Michael
Hi Michael,
This issue has been fixed in Premiere Pro CC 12.1.1: Bug fixes in Premiere Pro versions 12.1 and 12.1.1
Let us know if you're still seeing this issue.
Rameez
Yes, its a bug, they're working on a fix, and at least one thread has a promise for a patch very soon. No real idea.
There are several workarounds, but no pattern to which workaround works for which user.
https://forums.adobe.com/thread/2475353
One user successfully nested the pngs, and I wonder if it was a sequence. So try that: Create sequences with one png sequence each, then use those in the main sequence.
Also, be aware of the new bug/feature request system; this one has gotten attention:
Rather than wait and leave the client hanging, I would batch convert them to 32bit Tif with Photoshop and move on.
Hi Michael,
Rameez
I'm running 12.1.2 and I still have the same bug. What premiere do I need to revert back to and how do I do it?
Hi carlj,
The issue was fixed in Premiere Pro CC 12.1.1. I'm surprised to hear that you're still having the same issue.
I suspect you might be running into a similar but not the same issue. Do you mind providing screenshots or a video recording of the issue? A lot of Windows users have been running into an issue where they would see purple and green stripes while previewing their footage. This article provides more details and a solution to that issue: Green or purple streaks appear in the Source and Program monitors
Report back and let us know what you find out.
Best,
Rameez
