Hi there,
I'm having this problem where every time i try to use the lasso tool to select and free transform some area of my painting, it starts to drag the canvas like i was using the move tool.
This happens when i try to select AND when i try to transform, warp or any of those functions.
Does anyone know any fix for that?
Hello, the fix is to apply a Windows update that cures the issues created by a previous one : Cannot paint with stylus when zoomed in on image | Windows 10
Hi
What version of Photoshop and OS do you have, also do you use a graphics tablet?
Adobe Photoshop Version: 19.1.3 20180323.r.293 2018/03/23: 1163761 x64
SO: Windows 10 with update kb4093112, from yesterday.
I'm currently using a Wacom Intuos Pen Small CTL-480
Take a look at this thread
Thank you.
I would thing that the update beonf a cumulative update would include KB4089848 users have problen with. I use a Wacon Intuos Pro small and older wacom version and an older Wacom device driver. I have confifure Wacom to use wintab API for Photoshop to support older Photoshop versions I has a few version of Photoshop installed. I do not have Problems othther then Photoshop bugs.
If you are zoomed way in and your image does not fit in photoshop image display area the image should pan when a tool like the lasso tool nears the edge of the image display area. It should scroll the document not the layer. Some Winnows users had Panning issues after Microsoft update KB4089848. The document pans when it should not be panning when you use some tools. The lasso tool may pan whenever you move the cursor not only pan when you reach the edge on the display area.
When the canvas size is fit to the screen, it works fine.....But when i zoom in an area of the drawing, instead of transforming, warping or distorting said area of the drawing, it drags the canvas or even the whole PS window.
Didn't had that issue yesterday.
Also, the size of the UI/Interface is big...The buttons and panels are bigger than what it was. Like i'm using it in 1366x768 instead of 1920x1080, even thou my screen resolution is set to 1920x1080. The UI scalling is set to Auto, but even at 100% it doesn't change.
UI scaling does not use the Photoshop Preference in Windows 0 and Photoshop CC 2018 19.1.3 it your windows 10 Display scaling setting that is used. Some Windows user have problems with Windows update KB4089848 I do not When zoomed in the bush with a normal spacing setting not 1% there is not lag and the image is not panned on my machine. I do not use Windows INK API with Photoshop everything else uses INK. I have old versions of Photoshop install that]xx only support WinTAB API...
Thank you very much. I didn't knew it was attached to the OS scaling, and mine was set to 125%.
