Hi everyone!
I have an issue with Ps+wacom. When i scale my workspace it starts to scroll instead of drawing.
I never had this problem before, and i didnt change any settings, it started after Windows update.
Does anybody know how to fix it!?
Hello, here is the recommended fix, from Microsoft, as relayed by the Photoshop team: Cannot paint with stylus when zoomed in on image | Windows 10
Hi
Please search before posting. This has been answered several times today
The latest windows update (KB4093112) has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following (recommended) :
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the tablet properties and uncheck "Use Windows Ink"
4. Restart Photoshop
That is it - all should now work well (you need to do all the above steps to retain pen pressure)
Note : There is a third option. Microsoft made this change intentionally and they have issued a way round it with registry change (see link below). However for Photoshop the PSUserConfig method works.
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
Dave
It is not working, why 100 peoples post this advice?
Because that is the cause and the fix. To use the PSUserConfig.txt fix you must type it exactly as written
Microsoft have published their alternative registry fix at the link below so you can try that:
https://support.microsoft.com/en-ca/help/4093112/windows-10-update-kb4093112
Dave
Thanks. Er, Dave. Did search first. This post came up first. Try advice first, admonishments later?
I had the self-same problem and none of the individual fixes worked. I got in contact with Adobe help and they took me through all the steps to fix it. It required all of the actions to make it work. I had been trying one at a time and individually they didn't work, and so had undone each supposed fix.
This is what Adobe suggested and what worked for me:
Step A: As is recommended by ACP, start by adding the registry key, follow this link to find out how: https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10/
Step B: Type Windows Button + R, Type Go to App Data. A browser window opens, Click on App Data > Roaming > Adobe
Rename "Adobe Photoshop CC 2018" to "Adobe Photoshop CC 2018.OLD"
Step C Now do as ACP says above:
"1. Use notepad to create a text file and type in :
UseSystemStylus 0
4. Restart Photoshop"
Alternatively, go to Adobe help, tell them the problem, let them take over your machine and fix it for you!
I hope that helps!
Ivor
Do you save the PSUserConfig file in the Adobe Photoshop CC 201x.OLD folder??
Hi
No in the exact folder as described but substitute 2017 for 2018 if that is your version.
However, see last post by PECourtejoie. Microsoft have now issued a fix making workarounds unnecessary.
Dave
