Hi when iam trying to use the Brush tool with a microsoft Surface 2017 and a surface pen -
the pen draws sometimes a line (like expected) but sometimes the brush tool moves my canvas (drawing area)!!
Does someone knows this problem and a solution?
thank you
best regards sno
I was having the same issues while using my Huion Tablet Monitor, I wasn't able to fix the problem following the suggestions above, but I did discover the initial problem Is indeed with the update, it did not install properly and Microsoft has an update to fix it. Here is a screenshot of what is says on Microsoft's website:
and here is the link to the site:
https://support.microsoft.com/en-us/help/4093105/windows-10-update-kb4093105
I downloaded this update and installed it, and now everything i
...Copy link to clipboard
Hi
Try uninstalling this Windows update
You can also pause Windows updates for up to 35 days to prevent it been re-installed by going into advanced options and turning on Pause Updates
Also take a look at this thread
It really worked like a charm! I was frustrated for two days as I was not able to complete my work! Now I can! :')
Thats it !! thanks for this super fast reply!
Microsoft introduced new Windows Ink Pen behavior in a recent Win10 update. This causes your pen to pan the canvas in Photoshop. For more info, and instructions to revert to the old behavior, see this post:
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10/
Thanks LazyNezumi . I'd already switched to the Wintab use this morning. It does make you wonder what Microsoft are playing at making a change like that in teh background without a simple interface switch.
Dave
They have a history of introducing awful default-on features, so at least they're staying consistent!
if you have problems with your pen (my pen drags my workingfield to all directions when i use the brush or pencil) go to setup wacom tablet and go to calibrate (your pensil) and deselect Windows-inkt (left under) it could be that after the next update it wil be selected again, so deselect again if you have some troubles again. good luck.
hey there, can u tell me how can i remove the update? I have the remove option for security update but there's no remove button for system update!
No need to remove the update you have two choices you can either
Do the following:
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping uncheck "Use Windows Ink"
Or
Run this command on an elevated Command Prompt
reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f
thank u so much. it fixed
You're welcome
Thank you so much! This worked perfectly! I had to log out of CC and log back in for it to take effect but it's working like normal again! My workflow was suffering and I was becoming extremely frustrated so I wanted to be sure to respond and say thanks to you for your help!
Thanks so much! I was having the same issue and this was a lifesaver!
Seriously thank you so much.
thanks man! thats great!
Thanks a lot... I was already going nuts!
Thank you very much. I wasn't able solve this problem over one week. Thanks again!!!!!!
I found a reddit post from someone in the microsoft community apparently, and they said if you run this as an admin in the cmd box, it will fix everything without needing to uninstall anything. I did and it worked for me.
"reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f"
of course, without the quotations.
I downloaded this update and installed it, and now everything is working fine and I'm able to use my pen again.
Hope this Helps
