Hello, my name is Carlos.
Photoshop CC has always worked perfectly until yesterday, when I accepted to make an update of Lenovo (PD Firmware Update Utility, version 1.3). Right after that, I wanted to draw with my pen, but instead of painting strokes, it dragged the canvas around...
I realize this is *not* Photoshop's fault, but Lenovo's. Lenovo would fix the problem, but I won't get my computer back until within a month. I'm a professional illustrator so my income depends on this. Lenovo said that you could perhaps provide me with a "patch", so I could use Photoshop again despite Lenovo's faulty update.
I would greatly appreciate if you could help me, as soon as possible.
Best regards,
Carlos
Hi Carlos
Try this
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7
...Copy link to clipboard
Hi Carlos
Try this
7 Reboot
This issue was caused by Microsoft
More info
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10/
Thank you so very much for your help, it worked! I had absolutely no idea the problem was caused by Microsoft. You have saved me a lot of trouble... Again, thank you very much!
Carlos
No worries, glad I could help
THANKYOU SO MUCH!!!
