White Balance modification - ACR vs LR Classic
Apr 13, 2018 Apr 13, 2018
TIL: in ACR you can draw a rectangle with the dropper to select an area when modifying the white balance.
To do this, you open the image in ACR and on the top bar, take the first eyedropper tool - you can then "paint" a rectangle on the image to modify the white balance using the range of colours within the rectangle.
This doesn't work in Lightroom - you can only change it as a single point.
Am I missing something in LR? And if so, how can I do this in LR?
If not, why are these two behaviours different? I thought ACR and LR Develop were basically the same engine!
898
Are you sure about that? I'm using the latest camera raw on my Windows 10 computer, and I can't seem to replicate the action you are describing. I can create the rectangle, but it's the and as I try to modify the white balance the rectangle disappears and the white balance adjustment affects the entire image. Perhaps I'm missing a step.
You mark the rectangle to create a wider selection of colour values to change the WB on the whole image. That's what the white balance modification does. In ACR, the rectangle is available, in LR Classic it is not.
Okay, if you insist. But it doesn't work that way for me. I'll wait to see what others have to say about this. I have no suggestions on how to fix it for you.
Advisor ,
I dont believe you are missing anything. While I have never thought to drag an area with the white balance tool - dont use ACR much - I can confirm that I also cannot do it in Lightroom.
@JimHess Dragging the box does affect the final overall WB based on the content in the box. It is not a selection that persists.
mac OS Sierra
Then I guess I'm not following the logic. Apologize for my ignorance or stupidity or lack of understanding.
Jim,
The rectangle isn't a selection that will keep the white balance change within that selection, if that's what you think. It's a way to increase the size of the sample you use to set the white balance. But you still set the WB for the whole image, obviously.
-- Johan W. Elzenga
Yes that is my expectation also. When I select the WB picker tool and select a particular area it utilises 5 x 5 pixels to adjust the white balance of the select to make that 5 x5 pixel area as neutral however it adjusts the entire image. I can not see any way to adjust the size of the select. See the screen capture.
Regards, Denis: iMac 27” mid-2015, macOS 11.7.10 Big Sur; 2TB SSD, 24 GB Ram, GPU 2 GB; LrC 12.5, Lr 6.5, PS 24.7,; ACR 15.5,; Camera OM-D E-M1
You can adjust the box pixel dimensions by using the SCALE Slider on the toolbar or using the mouse roller.
OK Bob that is confirmed, just different ways of "skinning the cat" as the saying goes. Learn things every day.
Apr 14, 2018 Apr 14, 2018
This behavior was improved awhile back.  Originally you could change the pixel size of the box to SEE more of the area you were picking but the white balance and display number was still chosen from a 5X5 grid in the center.  After a big discussion on the forum with some Adobe people they agreed it would be better to use all the pixels in the larger grid.  Good job Adobe.
Is that in the current release? If so, it's a good start!
P
The change was made a year or two ago to the new eyedropper behavior.
I change the 'Pixel' sample with the mouse scroll wheel-
or the scale slider on the Tool bar
Edit: Bob, beat me to it
Many thanks to all for the information. I guess it's just a difference between ACR and LR CC. I'd really like to see the ACR implementation reach LR Classic though. It can be really helpful to use a larger source for setting WB. The larger box in LR is fine but you're still choosing a very small area to select the WB.
Thanks.
