I'm trying to draw using a sandstone texture with a scratch mark type Brush. But I don't see a way to add a texture. I know I can brush with colors, but I want to brush with a texture, is there a way to do that?
I see many you can download from the web if none of the brushes that install with Photoshop meet your needs. With CC 2018 you also get access to all of Kyle's brushes.
Thanks but thats not really the answer I'm looking for. I want to add my own. How do I do that?
Here's how you can add it to a brush - https://blog.redbubble.com/2014/02/how-to-make-your-own-brush-textures-in-photoshop/
You can add a texture to a brush in the brush settings:
You can choose which texture you add to your brush from the drop down menu and set how strong the texture effect is in the settings as well:
You can make your own texture by creating a pattern from a texture you like in Edit/Define Pattern. This pattern will then appear in your drop down menu of textures to choose from to add to your brush tip in Brush Settings.
