Hi there,
I am having problems opening my .psd file. I haven't changed the directery or map that it's in. I cleared my videocache but that didn't work for me.
The popup says the following: Could not complete your request because of a program error.
I saved it regularly and all of a sudden i cannot open it, i can however still open other .psd files in the same directory/map.
I really need this fixed asap because it's my portfolio design for my internship!
Who could help me out?
Josh
Have you tried resetting Photoshop's preferences?
Win: Press and hold Ctrl+Alt+Shift immediately after initiating Photoshop's startup. A box will appear asking if you want to continue with the reset, select "yes." If you don't see this, you weren't fast enough...Try again.
Mac: Press and hold Cmd+Opt+Shift then start Photoshop. A box will appear, asking if you want to continue with the reset, select "yes."
Also, take a look through this thread:
"Could not complete your request because of a program error" upon Open
I have tried it but that doesn't seem to work for me
I have looked at that thread you shared, the error logs that i'm getting are the following:
2018:04:14 20:07:07 : ..\..\sources\ULinkManager.cpp : 1521 : REQUIRE failed
2018:04:14 20:43:54 : ..\..\sources\ULinkManager.cpp : 1521 : REQUIRE failed
2018:04:14 20:44:29 : ..\..\sources\ULinkManager.cpp : 1521 : REQUIRE failed
Do you have any knowledge on this perhaps?
Could you please tell us which operation system are you using?
I am using Windows 10 and running the Adobe Photoshop CC 2017 version, it also doesn't work in the 2018 version
