Just a few moments ago I accidentally closed my sequence window. I am new to using Premiere Pro so I thought that closing my sequence meant I had deleted it entirely. In doing so I followed online tutorials and discovered the route of opening and/or importing the most recent Autosave file which I remember was automatically made only 20 minutes previous to this happening.
But, trying both methods (opening a previous project and importing the most recent autosave file) the best that could be recovered was an autosave file from last night with over half of the sequence missing. There are a dozen or so ''missing preview files'' that cannot be found or linked by Premiere and for some reason the most recent autosave file in my file is from last night although it autosaved several times since. The project bin doesn't contain any files before last night either.
By the way, I'm using Premiere Pro CC 9.0 2015 and I am a student using my university's software that I cannot update.
Is this a known issue and is there anything that can be done about it? I'm on a tight deadline and this is 10 hours of work gone.
Open your project. In the Project Panel, find the sequence you closed. Double click on it and it will re-open in the timeline.
If you don't remember the sequence name, the sequence(s) will be indicated in the icon view by this symbol:
or in the list view:
Double click on the sequence in the Project Panel to open it.
MtD
Thanks for the response. The only sequence in my project panel is a an older one from last night.
Do you have any bins in your project panel? Make sure the sequence you are looking for is not hiding within a bin.
MtD
This is all I can see.... the sequence 2nd in from the left on the top row is the old sequence I was referring to
I've also managed to find these files but they were added yesterday evening also and because there are no details on these files, I can't relink them in my project because I don't know what files they are... All I know is that these are not the most recent files from the project. I think I'm going to have to just cut my losses and do it all again.
I've realised these files are clips in my old sequence..... all these clips are no longer playing in the sequence
back to square one-ish
Make a habit of making a Save a Copy to another drive.
I dont trust auto save.
Did not save to the cloud by any chance?
No, foolishly I trusted the computer and didn't manually save any work since this morning. At the very least i screen recorded a lot of what I had done up until then which will help me remember how to do it again... It was a very dense edit
Thanks for the response but the only sequence in my project panel is an old once from last night.... Its as if all work from today has just disappeared off the earth along with the autosaves....
