Hi everyone!
Recently I upgraded my PrPro to 2018 ver. And I noticed some changes in workflow. In early versions I used any sequence like a clip in another sequence and there was no problems. So, after upgrade I can't drag and drop any sequence into another sequence and use it like a clip. Instead, the clips in that sequence inserts separately as is in that sequence. I have to make a new sequence from sequence and only then I can use it like a clip. How to fix it?
Thanks a lot for every comment!
Click on the top left icon just below the timecode numbers, this toggles between adding a sequence or adding separate clips.
