I have read a lot on here and I cannot find a way to vertically align text to a text box in muse.
Here is an example of what I am trying to do:
Responsive vertical align with CSS
I cant seem to find a way to do this in muse. Am i missing something or is this not possible?
You can assign a graphic style to a text box and then make custom code in the page properties metadata section to call it by name (style in this example)... I did have a dozen sample pages but they have all been deleted from Adobe BC this week, sorry.
yes html text is different to css text... Muse is a html maker and you would need to use padding to make that
another work around would be to add the css code as a insert[ed] html or you could also use a style (not in some small devices) but html is the best option for most senarios
Since padding is a static value, this does not work. My site spans the width of the browser and everything is responsive. If I pad, it only looks good at the size created. I could use a million breakpoints but it kinda defeats the purpose of using muse
there are 3 options and the code is not going to change because you need it to... use a work around or make a different design are the bottom line
thanks for the reply. I have used CSS inserted as a style in muse, but I am having a difficult time getting it to work with a text box. It seems like I need a container for the text box, but I cant see that muse allows this
