SOLVED
Sightly : How to Iterate through Map<String,Object>
Avatar
Level 2
Hi ,
I am not able to iterate the map in sightly. The map is having values as a bean object which i am not able to get in sightly.
I am able to get the keys directly but for values i understood there has to be a second loop since it is an object .
the code i have tried :
<sly data-sly-use.model="package.Model"/>
<sly data-sly-list.keyName="${model.map}">
<li>keyname = ${keyName}</li>
<li>keyvalue = ${model.map[keyName]}</li>
    <sly data-sly-list.key = "${model.map[keyName]}">
    BeanData= ${key}
                <ol><li>${key.text}<li></ol><br/>
    </sly>
</sly>
Here in my code keyname is printed on the page but keyvalue is not.
In java class the map is of type : map<String,Bean> and Bean class have the data members which i want to retrieve like text.
Please guide where am I going wrong.
I have already gone thru many links but couldn't find the solution.
Links referred:
Sightly : How to Iterate through Map&lt;String , Map&gt;
Iterating a map in sightly which have custom object as key
How to traverse a Map having Keys of Object Type using Sightly ?
1 Accepted Solution
Avatar
Correct answer by
Level 2
Hi Feike,
Thanks for the instant replies.
I made it work :
<div data-sly-use.hashmap="com.adobe.examples.htl.core.hashmap.HashMapExample">
  <sly data-sly-list="${hashmap.map.keySet.iterator}">
     <li>key = ${item}</li>
     <ul data-sly-test.beanObj="${hashmap.map[item]}">  //This should be data-sly-test, no need to iterate again
          <li> text = ${beanObj.text}</li>
     </ul>
   </sly>
</div>
Avatar
Level 2
yes fieke i saw but i couldn't understand how will i get that specific data member from my bean class. Could you please help me understand.
I have a data member "text" in a bean class which i m returning using a sling model ->map.put(key,bean).
As per the link :
     ${item}
     <ul data-sly-list.aem="${hashmap.map[item].keySet.iterator}">
      <li>${aem} ${hashmap.map[item][aem]}</li>
     </ul>
</div>
How can i fetch my data member "text" using the inner loop?
Avatar
Employee
I would think this would work in your case ${hashmap.map[item].yourProp}
Avatar
Level 2
Thanks for the reply feike but  this ${hashmap.map[item].yourProp} is not working.
Avatar
Level 2
Infact it is not going inside the inner loop.And i tried printing the value of ${hashmap.hubarticle[item]} but nothing is getting printed.
This is what i have tried:
<li>value = ${hashmap.map[item]}</li> //This is not printing anything(This should be the beanObject logically)
<li> text = ${hashmap.map[item].text}</li> //Here, "beanObject.customProp" should work but it is not printing
</ul>
   </sly>
</div>
Can you please have a look fieke?
Avatar
Correct answer by
Level 2
Hi Feike,
I made it work :
     </ul>
   </sly>
</div>
