So, as long as I don't zoom out, my brush works fine. But as soon as I zoom in or use the move too or do anything other than paint, it starts freaking out and moving the screen around instead of putting down brush strokes. This just started randomly happening in the middle of a piece, and I can't figure out how to fix it.
Included is a link to a gif of what happening!
Hello, apply this Windows update that fixes the issues created by the previous one: Cannot paint with stylus when zoomed in on image | Windows 10
This is happening to me and several others commenting on the site. Its been really troublesome all day today since the Windows update. I'm hoping to call in tomorrow to find a solution with someone, but I have not found one yet in my own troubleshooting.
I got the same issue.
Any solution yet?
I'm having this problem too, and i cannot figure out what is causing it!
Hi
Please search before posting. This has been answered several times today
The latest windows update (KB4093112) has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following (recommended) :
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the tablet properties and uncheck "Use Windows Ink"
4. Restart Photoshop
That is it - all should now work well (you need to do all the above steps to retain pen pressure)
Note : There is a third option. Microsoft made this change intentionally and they have issued a way round it with registry change (see link below). However for Photoshop the PSUserConfig method works.
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
Dave
Is this only causing issues with Photoshop 2018?
2017 installed here, and had the same issue. The PSUserConfig fix worked for me.
I’m not sure how to do that. I can open notepad, but it won’t allow me to save to specific locations
You may need to check "Hidden Items" in File Explorer
Dave
I did this yesterday and It did fix it. it is not working today.
Which fix did you apply , the first the second or the third?
Dave
I have the brush back but lost pressure sensitivity. How did you retain those settings?
Unchecking windows ink resolves the canvas issue. The PSUserConfig.txt file restores pen pressure and tilt.
Note the content must be exactly as posted and the file needs to be named PSUserConfig.txt and located as posted. (Make sure you allow notepad to add the .txt extension or you will end up with a file named PSUserConfig.txt.txt which will not work)
Dave
I was able to fix the moving canvas issue by uninstalling the windows update but I have a new problem. When I go to draw, it activates one or both scroll bars and they turn white. It will not allow me to draw at all, it just moves the scroll bars but the canvas remains still.
additional information: the scrolls will go back to normal when my stylus or mouse hovers over it. If I tap with the stylus, color will show up without any problems, but as soon as I drag it will not let me. This occurs on and off. Last night when I uninstalled the windows update, it worked for hours. It isn’t working again. Sometimes I can get a few brush strokes in, but only for a minute at most.
i'm using a surface pro 2017, with a surface pen. i found that photoshop was registering my pen as right clicks, as opposed to the usual leftt clicks, thus activating the drag that would happen when i right click and drag with my trackpad. i don't know it it would work for any other tablets, but pushing the right click button on my pen seems to have at least put a band-aid on the issue.
frankiec79728074,
Thank you for that suggestion - this was the only solution for me! I am using a Surface Book, and I've tried all the above suggestions, in addition to uninstalling and reinstalling an earlier version of Photoshop, experimenting with disabling/enabling Microsoft Ink, with nothing working until now. Thanks a bunch
It came to iMac the same, any solution?
