The problem with the work of the graphic tablet in Photoshop
Apr 17, 2018 Apr 17, 2018
when the graphic pen is pressed in Photoshop, the settings are dropped and instead of drawing by the brush, scrolling is turned on. And this happens randomly scrolling the brush scrolling .. in the pen settings are correct at the same time
250
Deleted User
You still haven't mention your operating system, if it's windows 10 try one of these
1. Use notepad to create a text file and type in :
# Use WinTab
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping  uncheck "Use Windows Ink"
Or
1 Select everything inside the quotes here (don't include the quotes
Adobe
Guest
Hi
You don't mention what OS or Photoshop version you have, but your issue could be related to this
Photoshop - Wacom - Latest Update Bug
СС 2018 version
Guest
# Use WinTab
UseSystemStylus 0
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7 Reboot
If you use the first option you may need to enable hidden items in file explorer
Thank you so much! helped me
