I need help. Can someone fix this?
Hi
Try either one of these, I assume you're on Windows 10
If not please provide more info
1. Use notepad to create a text file and type in :
# Use WinTab
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping uncheck "Use Windows Ink"
Or
1 Select everything inside the quotes here (don't include the qu
...Copy link to clipboard
Hi
# Use WinTab
UseSystemStylus 0
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7 Reboot
You may need to enable hidden items in file explorer for the first option
Thank you. i'll try
it work but i can't use opacity or pen pressure.
Sorry but you really need to provide more info, exactly which option did you try, what Operating System and Photoshop version are you using and what kind of tablet do you have?
I choose the second option what you give me and it work. Thank you very much i really appriciate what you did for me. Thanks again.
