After the update previous to the one I installed last night, DC became erratic again, randomly crashing while trying to scan and create PDFs. I had hoped that the newest update fixed the problem, but it did not. The problem has only gotten worse. Adobe, each time you send out a new update, this issue comes up again. It is a huge problem for me, as I use the problem mainly for this purpose. Anyone else, having APPCRASH upon scanning?
We apologize for the issue you are facing. Can you please share the logs to help us understand the issue.
To create crash logs please follow these steps.
1. Retry the scenario where Acrobat crashes
2. Do not close the pop-up when Acrobat crash
3. Open Task manager
4. Right click on “Acrobat.exe *32” process and select ‘Create Dump file’
5. It will create a log file in temp folder. (Path will be displayed on pop-up comes when logs created). You can also check this under
Please follow the steps to share the file using Adobe send - https://cloud.acrobat.com/send
Thanks.
I have just sent the log.
Where did you sent the logs. Can you please share the link where you upload the file here.
Thanks.
I uploaded them as you requested on 2/27. I just did it again and sent you an email invitation to the upload. I am doing so much more work here than anyone at Adobe. In the future, I do not want to have automatic updates. They just screw everything up. After this is corrected, I would like you to let me know how to turn off automatic updates. Thank you.
Afternoon,
I am also experiencing this issue with a few of my users. I have reinstalled Adobe and as well as adjusted to run in compatibility mode for windows 7. I have the .DMP file, where may I send it for your review?
You can use following link to share the crash logs.
How to share a file using Adobe Document Cloud
Thanks.
Adobe - Please review the link to the dump file to assist in determining what is causing issue.
Hi there
I have the same Problem, it seems!
Tried to get a Screenshot, just before, the Software was closed:
Here's my Dump File: Dateien freigegeben - Acrobat.com
Do you have proposals for me?
thanks
Dieter
We have analyzed the dump files.
Unfortunately there is no valid information present in the dumps that can help us identify the issue.
Repeat the steps where you observed the crash and follow these steps to create a crash dump.
1. Create c:\temp\
2. Download from dropbox.com/s/w9itsczht3cs7sq/Procdump.zip?.. and extract into c:\temp.
3. Make sure no Acrobat instances are already running — check via Task Manager.
4. Launch Acrobat
5. Launch CMD prompt and type “cd c:\temp”
6. On the command-prompt type: “procdump -e -ma Acrobat.exe c:\temp\01.dmp”. Procdump will now wait for the crash to happen.
7. Perform the actions in Acrobat that cause it to crash.
8. Procdump will have created at c:\temp\01.dmp.
Go through the link forums.adobe.com/docs/DOC-7161 to share the dump or share it in whatever way you’re comfortable with.
Also please share the video of the steps you have done when you observed the crash.
Thanks.
