I need to create a system that will allow a user to position something on a layer and use that as a marker for containing a position for me to get a position with code. My current solution is adding a "Marker" layer to the document and using that as a reference to the position (x, y) where I want the point to be added.
In the perfect World I would like to right click and use a 'Set Marker here' drop down and have them drag around a marker sprite to the position they need, from there I could reference some sort of data object in the scene to get that marker position. That's the perfect example.
Could I accomplish anything like this? Or any other design like piggy backing off another class that can be positioned in a layer like a Anchor to return the position of the class.
I will be extending this to the C++ API, I just need to know what exactly PS can do in terms of what I am looking for.
Thank you in advance!
Color samplers are easier in scripting than counter tool
Hi i73
How about across hair of two guides? IMHO a better aligning possible than a pixel "marker"
Thatnks Pixxxel,
Yes, the Marker should be anything (sprite), that would just overlay the position the user needs.
You can't get the cursor position through scripting. But it is possible to get the position of a pixel (but a pixel has a dimension!) or the position of a guide or (as a possible woraround) perhaps the user could set a color sampler and the script reads it's position and set your sprite and will remove the color sampler after then.
For me, the pixel idea is a little Hacky, and it won't be able to be seen by the user on a 2k image, and it's not something that a user can move around after it's set so it won't work for me.
Looking at the current tools, thinking I could find some sort of anchor tool. I was messing around with the 'Count tool' :
You can see I added the numbers to the scene, this could serve it's purpose with what exactly I need, do you know if there is something else (That would work better) like this that I could access the data like that?
Or can I access the numbers positions in the scene + their value?
If I have access to that I will go with this solution.
Ah, did not know about that, thanks if I have any further questions I'll ask
Here is some code for the counter tool...
#target photoshop;
var ref = new ActionReference();
ref.putProperty(charIDToTypeID("Prpr"),stringIDToTypeID("countClass"));
ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
var desc = executeActionGet(ref);
if(desc.hasKey(stringIDToTypeID("countClass")))
var Count =desc.getList(stringIDToTypeID("countClass")).count
for(var z =0; z < Count; z++){
var X = executeActionGet(ref).getList(stringIDToTypeID("countClass")).getObjectValue(z).getUnitDoubleValue(stringIDToTypeID( "x" ));
var Y = executeActionGet(ref).getList(stringIDToTypeID("countClass")).getObjectValue(z).getUnitDoubleValue(stringIDToTypeID( "y" ));
$.writeln( "X= " + X + " Y= " +Y);
countClear();
function countClear(){
executeAction(stringIDToTypeID("countClear"), undefined, DialogModes.NO);
Thanks Merlin!
One question am I correct with saying that 'classColorSampler' will be for accessing the color sampler?
i73 schrieb
Thanks Merlin!
No.
That's AM-code for count class.
Here is a equivalent for color samplers
// https://forums.adobe.com/thread/2307227
var orig_ruler_units = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
message="Canvas Width=" + app.activeDocument.width.value + " ,Height=" + app.activeDocument.height.value;
for (var s=0 ,len=app.activeDocument.colorSamplers.length; s<len; s++) {
var colorSamplerRef = app.activeDocument.colorSamplers
;message = message + "\nColorSampler=" + s + " ,x=" + colorSamplerRef.position[0].value + " ,y=" + colorSamplerRef.position[1].value;
alert(message);
app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
Have fun
doc.countItems
Not?
This gets the position of the first colorsampler.
var mySampler = app.activeDocument.colorSamplers[0];
var xy =mySampler.position;
alert("X = " + xy[0] + " Y = " + xy[1]);
Hmmm, I don't have access to the `app.activeDocument` This is in C++ so, off the top of your head would you know if I have access to the class with the 'classColorSampler'?
My code will basically look something like this:
error = sPSActionControl->StringIDToTypeID(classColorSampler, &typeID);
error = sPSActionDescriptor->GetList(result.get(), typeID, &piActionsList);
//Iterate through the piActionsList
Just need to check if the class I am looking for is 'classColorSample`
As far as I can remember ColorSamples have a maximum of 4 pieces )
10
https://forums.adobe.com/people/pixxxel+schubser
10
Please prove it
written by r-bin:
Please prove it
Yes, I did (in CC)
Oh, I don't think this solution would work then, I need access to more than 10. Can I override it more than 10?
Unfortunately no. But with the hints of @r-bin and @SuperMerlin you can do the same with the Count Tool (DOM version)
for (var s=0 ,len=app.activeDocument.countItems.length; s<len; s++) {
var countItemRef = app.activeDocument.countItems
;message = message + "\ncountItem=" + s + " ,x=" + countItemRef.position[0].value + " ,y=" + countItemRef.position[1].value;
alert(message);
Have fun
hope this helps
ref.putProperty(charIDToTypeID("Prpr"),stringIDToTypeID("colorSamplerList"));
if(desc.hasKey(stringIDToTypeID("colorSamplerList"))) {
var Count =desc.getList(stringIDToTypeID("colorSamplerList")).count
var X = executeActionGet(ref).getList(stringIDToTypeID("colorSamplerList")).getObjectValue(z).getObjectValue(stringIDToTypeID( "position" )).getUnitDoubleValue(stringIDToTypeID( "horizontal" ));
var Y = executeActionGet(ref).getList(stringIDToTypeID("colorSamplerList")).getObjectValue(z).getObjectValue(stringIDToTypeID( "position" )).getUnitDoubleValue(stringIDToTypeID( "vertical" ));
