In prior versions LR had a Face button (see below) to initiate Facial Recognition. In version 7.3 it seems to be missing and I also can't find it as an option in the dropdown menu to display.
I give up... where is it?
Actually found it! Had to go to Compare or Survey, then toggle view mode for it to show up. It then remains in Grid view as well.
You either have NO photos selected or a more likely scenario is you have the view modes turned off. Click the little triangle on the bottom right to get the following dropdown.
Thanks for your reply but the Face is missing regardless of whether any images are selected and I've toggled through all the options under View Modes as well.
