I updated Java and CS5.5 won't work on my Mac High Sierra 10.13.4.....
Apr 17, 2018 Apr 17, 2018
I updated Java and CS5.5 won't work on my Mac High Sierra 10.13.4.  Can anyone help me to get this running?
Thank you,
Tom
2.1K
LEGEND , Apr 18, 2018 Apr 18, 2018
That message indicates that the installation didn't work properly. Part of the application is missing. You need to remove the entire setup and reinstall from scratch.
Understand that CS5.5 is no longer supported and your best bet is to upgrade to CC 2018.
Adobe
I believe on a Mac Adobe may use some system Java installing Photoshop.  Once Photoshop  is installed Photoshop Scripts written in Javascript are process via Photoshop's  Plug-in.  Look at your  Photoshop menu Help>System Info.  In there make sure it is loading. ie you should see something like this listed:   ScriptingSupport version xxx.xx - from the file “ScriptingSupport.8li”
JJMack
JJJMack,
I cannot open Photoshop now.  After it asked to upgrade Java SE 6, I'm getting this Mac Error Message:
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @executable_path/../Frameworks/ahclient.framework/Versions/A/ahclient
  Referenced from: /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/MacOS/Adobe Photoshop CS5.1
  Reason: image not found
Thanks for trying and your input.
If your getting the Java required message to open photoshop cs5.1, then you need the Java SE 6 from apple.
Download Java for OS X 2017-001
If it's something else not working, then you'll have to be more specific.
Jeff thank you for the response.  When I originally tried to open a file I got the message that I had to install Java SE 6.  I followed the link, but once it was installed it wouldn't start.  I cannot go into Photoshop'a menu.  I now get a Mac message that says in the paragraph:
Dyld Error Message:
Any help would be appreciated and thank you.
Do you use any virus scanning software on your mac?
Apr 19, 2018 Apr 19, 2018
Lumigraphics,
Thank you for taking the time to look thru my error messages.  I did as you suggested, completely uninstalled it, then reinstalled it.  As it's an older version, it just wouldn't install and kept asking to unmount the file.  I opened up the Terminal file I believe in Contents and dragged it to the Terminal Window.  Worked right out of the gate.
Thank you so much.  I like most of the world have been using Adobe for a long time.  Awesome that even though it's an older version I was still able to get the help I needed.
Best regards,
Tom
Jeff,
I downloaded this and it didn't start Photoshop.  I'm getting this message now from Mac:
Dyld Error Message:
Thanks for the reply.
Jeff,
Yes, I use Webroot.
I've tried disabling Webroot and staring Photoshop.  That didn't work.
