How do I set up a form to be signed by another person before I sign it. If I set up with signature field then when I get the form back I cannot sign myself. So I need a way to do multistage signatures
Hi Chrisbee,
We apologize for the delay in response to your query.
Looking at the description above, if you are willing to add your signature after getting the document signed by signer. The you simply place yourself (your email) last in the "Signing" order and your other signers first.
Following the steps suggested in the help document, when you place the signers email in 1st and 2nd place then add your email at the end and assign a signature field for yourself too. In this way once the other sign
...Copy link to clipboard
Hi Chrisbee,
Following the steps suggested in the help document, when you place the signers email in 1st and 2nd place then add your email at the end and assign a signature field for yourself too. In this way once the other signer have signed the document it will route to you and then you can add your signature on the same document.
Send PDF documents for signature, Adobe Acrobat
Hope this answers your query.
Akanchha
You can also do it by adding two signature fields, setting the first one to lock all other fields except for the second signature, when signed.
