I am now running RoboHelp 7 trial version. In the coming
weeks we would buy RH8. Could you please clarify the following?
1. Can we download and install RH 8 trial in the same
machine? If yes, should we uninstall RH 7 and then install RH 8?
2. When we buy RH 8, should we uninstall RH7 before
installing RH 8 or typing the product serial no.?
3. What else should we be looking at in this transition?
There are many of us with different RH versions on the same
PC with no problems at all so having two trials won't be a problem.
You won't have to uninstall the RH7 trial when you buy RH8 but if
(like me) you are of a tidy disposition you may want to.
Just beware that when you open a project in RH8 you will no
longer be able to open it in RH7. If you tend to open a project by
double clicking on the .XPJ file the file association will change
with the RH8 install. Therefore opening a project created with RH7
will convert the project to RH8. These projects will have to be
opened from within the RH7 trial to avoid the conversion.
I am looking at the whole RH8 package. I want to install all
the components; I am in RH HTML though.
Now I have all components of RH7 installed (That's what I
thought but only the pdf converter is not seen. I'll take care in
RH8 :)).
