Auto picking the most distinct accent color from an image
Participant ,
Apr 18, 2018 Apr 18, 2018
This might be asking way too much but I thought i'd put it out there...
Project:
I have written a script and action that reads file names (col.A) and Hex colors (col.B) from a csv file.
First it finds a file from a folder that contains an image of a lamp and shade, it removes the lamp and trims to the shade. Then it places the shade into another image that is a scene with a lamp. Now I have a new shade on the lamp in the scene. Ok, so that's all working! Here's where the color comes in.
The color was chosen from somewhere in the shade and written to the CSV file by someone. Currently, the script sets the foreground color and the action fills a layer with it and creates a clipping group and changes the mode to color. This works too!!
I have artwork, a pillow and a wall that have a color matching some highlight color on the lamp shade... Still with me?
Now for the challenge:
I was wondering if perhaps the shade (while it is open on it's own and after it's trimmed) could be sampled for the top say 10 colors as can be done when optimizing a GIF in "Save for Web" ( see resource (e) below). It would even work if the document was duplicated, reduced to 200 x 200 and then sampled. The vivid colors will still be there. My thinking is that the vivid colors are the ones with the greatest disparity between R, G and B.
Example: Grays are all 000000 to FFFFFF with RGB values that are always equal. Any colors that are more muted will be a combination of different R,G,B values but closer in value than a more vivid colors.
Example:
In the resources I listed below the image in (a) has a vivid pink flower R:244, G:0, B:145. Although the Red and Blue values are higher, Green is zero making for a very distinct color.  Here is another #d33aff is R:211,G:58, B:255
I think I have a formula that can determine the more vivd colors as a percentage.
Step 1: Take the 2 highest values of R,G or B and add the two.
Step 2: Divide the answer by 2 to get the average.
Step3: Divide the remaining value (the lowest of the 3) by the resulting average from Step 2
Step 4: Multiply by 100 to provide a percentage (rounded to the nearest integer)
Purple:  #ac5aab   R=172, G=90, B=171       The Math: 90/((172+171)/2)*100 = 52%
Orange: #fd971e   R=253, G=151, B=30        The Math: 30/((253+151)/2)*100 = 14%
Orange would be chosen out of the two.
I believe the lower the percentage, the more vivid is the color. Grays will always be 100% (OK, there is a question then if the image is Greyscale
I hope I'm making sense...
So my thought is that if the colors in the image could be evaluated and the one with the greatest variation in values be singled out, I would not need to manually pick it and write it to the CSV. In essence, the color could be chosen on the fly.
Tie Breaker
Often times the RGB values contain a zero. In that case the percentage will always be zero. This could result in a tie against another color. Both would be a vivid color but "there can be only one". I don't think it matters to me which is chosen at this point as long as one of them is picked.
Resources:
(a)  Here is a good one to work with. The color might be the pink, blue or orange.
https://www.lampsplus.com/products/peacocks-in-the-garden-giclee-droplet-table-lamp__k3334-15m02.htm...
(b)  More lamps with shades (bigger images on product pages)
https://www.lampsplus.com/products/s_k3334/?s=1
(c)  Here are some colorized scenes where the lamp base, art, pillow and walls were colored by script and action. All files named and saved automatically by script.
https://www.lampsplus.com/products/s_1r412/
(d)  This image is just a test but it is the result of using the method and formula from above.
test-color-selection?qlt=70&wid=600&fmt=jpeg&resMode=sharp2&op_usm=2,0.3,3
(e) Photoshop's "Save for web" allows the user to specify the maximum numbers of colors in a table. Could something similar be used to pick key colors for the purpose of this post?
save-for-web?qlt=70&wid=600&fmt=jpeg&resMode=sharp2&op_usm=2,0.3,3
Many thanks for reading through this and for any help or ideas that you may have.
This is way above my head but I know some of you geniuses might  have some thoughts.
Limey (Paul)
Actions and scripting
1.8K
Adobe
Have you considered utilising the S from HSB?
Participant ,
Apr 19, 2018 Apr 19, 2018
Thanks c.pfaffenbichler, I just read up on HSB and that sounds like a awesome idea! Essentially the "S" in HSB is the same as the percentage value that my calculation was coming up with. Yellow #fbda15 comes out to 8% using the calculation or S=92 in HSB. Purple #ac5aab is 52% with the calculation and S=48.
Your insight makes great sense and easier.
Then "all" that remains is sampling an image to determine which of the colors would be the chosen one. Is there a way to find the highest saturated colors in an image and ultimately pick one to update the foreground color? As I mentioned earlier, if it involves sampling the entire image, pixel by pixel, the original might be duplicated, reduced in size and then sampled.
I have been searching all over the forums for something that I might modify but not having a lot of luck.
Paul
People's Champ ,
Did not quite understand what you need.
If you need to establish what a saturated average color prevails in the picture, you can use this script
You need to have HSBHSL plugin installed
Optional Photoshop CC plug-ins
var min_saturation = 50;
// create tmp layer and move it on top
app.activeDocument.artLayers.add();
if (app.activeDocument.activeLayer != app.activeDocument.layers[0])
    app.activeDocument.activeLayer.move(app.activeDocument.layers[0], ElementPlacement.PLACEBEFORE);
// stamp visible to tmp layer
var d = new ActionDescriptor();
d.putBoolean( charIDToTypeID( "Dplc" ), true );
executeAction( charIDToTypeID( "MrgV" ), d, DialogModes.NO );
// call hsb/hsl filter (rgb -> hsb)
d.putEnumerated( charIDToTypeID( "Inpt" ), charIDToTypeID( "ClrS" ), charIDToTypeID( "RGBC" ) );
d.putEnumerated( charIDToTypeID( "Otpt" ), charIDToTypeID( "ClrS" ), charIDToTypeID( "HSBl" ) );
executeAction( charIDToTypeID( "HsbP" ), d, DialogModes.NO );
// select "green" channel
app.activeDocument.activeChannels = [ app.activeDocument.channels[1] ];
// threshold 128 ==> saturation 50% or higher
d.putInteger( charIDToTypeID( "Lvl " ), min_saturation * 255/100 );
executeAction( charIDToTypeID( "Thrs" ), d, DialogModes.NO );
// selection from current channel
var r1 = new ActionReference();
r1.putProperty( charIDToTypeID( "Chnl" ), charIDToTypeID( "fsel" ) );
d.putReference( charIDToTypeID( "null" ), r1 );
var r2 = new ActionReference();
r2.putEnumerated( charIDToTypeID( "Chnl" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
d.putReference( charIDToTypeID( "T   " ), r2 );
executeAction( charIDToTypeID( "setd" ), d, DialogModes.NO );
// remove tmp layer
app.activeDocument.layers[0].remove();
// get average color for selection
var c = new SolidColor();
if (!get_average_color(c)) { alert("Something is wrong"); }
app.activeDocument.selection.deselect();
app.foregroundColor = c;
alert(c.rgb.red + " " +  c.rgb.green + " " + c.rgb.blue);
function get_average_color(color)
    try {
        var chnl = 3;
        if (app.activeDocument.mode == DocumentMode.CMYK) chnl = 4;
        var lm = new Array();
        var px = new Array();
        for (var i = 0; i < chnl; i++)
            try { var hst = app.activeDocument.channels.histogram; } catch(e) { alert(e); return false; }
            var l = 0;
            var p = 0;
            for (var n in hst) { l += hst * n; p += hst; }
            hst = null;
            lm.push(l);
            px.push(p);
        if (app.activeDocument.mode == DocumentMode.RGB)
            var r =lm[0]/px[0];
            var g =lm[1]/px[1];
            var b =lm[2]/px[2];
            with (color.rgb) { red = Math.round(r); green = Math.round(g); blue = Math.round(b); };
        else if (app.activeDocument.mode == DocumentMode.LAB)
            var _l = lm[0]/px[0] * 100/255;
            var _a = lm[1]/px[1] - 128;
            var _b = lm[2]/px[2] - 128;
            with (color.lab) { l = Math.round(_l); a = Math.round(_a); b = Math.round(_b); };
        else if (app.activeDocument.mode == DocumentMode.CMYK)
            var c = 100 - lm[0]/px[0] * 100/255;
            var m = 100 - lm[1]/px[1] * 100/255;
            var y = 100 - lm[2]/px[2] * 100/255;
            var k = 100 - lm[3]/px[3] * 100/255;
            with (color.cmyk) { cyan = Math.round(c); magenta = Math.round(m); yellow = Math.round(y); black = Math.round(k); };
        return true;
    catch (e) { alert(e); }
Participant ,
Thanks r-bin! That does what you said it would but what I need is not the average saturated color that prevails in the picture but instead the "most" saturated and if tied with others, the brightest, and then by hue if it came to it.
So if this were equated to a sort in excel, and the columns were Hue Saturation and Brightness (HSB) I would sort by S(aturation) and then B(rightness) followed by H(ue)
Do you think the script that you shared could be modified to do that? I do have the plugin installed. I have attached a visual of what I am trying to accomplish.
Paul
hsb-sort-order?qlt=70&wid=600&fmt=jpeg&resMode=sharp2&op_usm=2,0.3,3
People's Champ ,
Apr 20, 2018 Apr 20, 2018
Again it is not clear what kind of colors they are and who sets them or chooses (and for what).
An image can contain as many different colors as there are pixels in it. Suppose you have access to each pixel. What colors (or one color) are you going to get?
Participant ,
Hi r-bin,
I don't know how to explain it any clearer than I have. I have laid out in pictures and words what I am trying to achieve. I need an accent color to be fed from the script to set the foreground color. The color would then be used as the accent color for items in a room scene. The color's origin is from an image of a lamp shade that will be placed in the room setting.
Using HSB the chosen color should be one that appears in the lamp shade that is very distinct. The color can be chosen by comparing pixels (colors) within the image and selecting those that are highly saturated. Id there are more than one color that has the same saturation, the tiebreaker would be the brightness. If there are more than one color that share the same Saturation and Brightness that the tiebreaker would be the Hue.
The above script is using the histogram to come up with an average saturation. I don't know if this makes sense but I suppose whatI need is the color on the top end of what it is averaging if it is averaging all saturations of colors. I need the most saturated and brightest color.
Paul
Participant ,
r-bin,
perhaps this will help. Please check out this site. This program/script finds a varierty of colors but I am after one.  I am looking for the "Vibrant".
I know this is an Android program but it helps to explain what I am trying to achieve.
Vibrant.js - Extract prominent colors from an image.
Paul
Participant ,
Apr 30, 2018 Apr 30, 2018
Here is another link where they are doing what I am trying to do. The vibrant color is what I am trying to capture in a script.
https://tympanus.net/Development/ColorExtraction/
Are there any coders out there that might have some ideas how to achieve this in Photoshop?
Paul
Sep 01, 2023 Sep 01, 2023
Hi @PS-Guru
Did you get the code for picking up the most vibrant color?
I am trying to do the same based on the histogram analysis, but if you already got the code, please let me know.
The thread is pretty old …
Could you elaborate on your process?
The histogram of what exactly are you trying to use – of an image, a Selection, …?
Hi
I have created a new post altogether.
Can you post a link to that thread?
