I was experiencing the same problem myself but have solved it.
Here's how (note that I'm compiling a Microsoft HTML Help layout and using RoboHelp 8):
1) Double click Microsoft HTML Help to start the process
2) In the window that appears, click the Edit button next to "Advanced Settings," near the bottom right
3) Click the TOC Styles tab
4) Click the checkbox next to "Single Click to Open Books"
5) Click OK
6) Click Finish to compile
Your change to the setting will be saved for all future compilations.
Hope that helps,
Billy
Hi Billy
What you posted would appy to the world of CHM files but not WebHelp. (The thread was dealing with WebHelp)
Note that the Single Click to Open Books option has a potentially undesired side effect. That is, when a new book opens, the formerly open book closes. In the Microsoft HTML Help Workshop (HHW) this option is titled differently than it is in RoboHelp. In HHW, it's titled Only Expand a Single Heading.
If you enable the Single Click option, it's also a good idea to also enable the Plus Minus Squares option. But what you will find is that the option is disabled in RoboHelp. That is, until you also enable the "Lines from Root" option.
Cheers... Rick
