In Lightroom 6.1.1, Windows 7 -- right click a folder in the left side folder list is supposed to show a contextual popup menu.
It doesn't work. Nothing happens.
Thanks for any help!
Mo
I would first try updating to LR 6.14, which is the last release of LR 6, and is a free update for you since you already own LR 6.
If that doesn't help, then try deleting your preference file.
Preference file and other file locations | Lightroom Classic CC and Lightroom 6
Also, try rebooting your computer. That sometimes fixes a balky Lightroom.
Thanks for the quick help, guys...
I tried:
- Rebooting computer
- Upgrading to 6.14
- Deleting preferences files
No change. Still no popup menu when right click on a folder.
Any other ideas?
Maybe you could post a full-resolution screenshot of your LR window, pointing out exactly where you're trying to click. Sometimes that adds context and points towards where the problem might be...
Here's a screen shot...
1. Does the problem happen when you right-click on a folder not marked with a "?", e.g. "Snap Photos"? (The "?" on the folder indicates that LR thinks it is missing from its original location. Right-click should work on such folders.)
2. If you right-click on a thumbnail in Library grid view, do you get a context menu?
3. If the answer in 2 is no, try right-clicking on a file or folder in Windows File Explorer -- do you get a context menu?
Good questions, johnrellis...
1. There is no popup (the problem happens) when I click ANY folder, whether it has the "?" or not
Also, no popup when click an item under Catalog or Collections
2. I DO get a context menu popup when click on thumbnail in Library grid view
3. See #2
More info:
4. The context menu popup DOES work when click a "heading" in the left column file menu.
Examples - these work fine:
- Click Collections
- Click hard drive
Totally strange...
Many thanks,
M
Agreed, strange symptoms.
Two more thoughts:
1. Are you using a generic mouse or a table/pen or some other device that requires special drivers? There have been occasional issues with such devices reported in the past.
2. Try making a new test catalog and import a few photos into it. Does right-click still fail?
...and:
3. Do you have the Windows 7 DPI scaling set to something other than 100%?
Get a better view in Windows 7 by adjusting DPI scaling - TechRepublic
1. I'm using Microsoft mouse
2. Made a new test catalog - same problem
3. Using max/recommended DPI - 1920 x 1080
Also
4. Tried using LR on another monitor that is attached to my laptop
Nothing works... Ugh!
There's always the last gasp: completely uninstall and reinstall, which infrequently solves such problems.
Yup. I had thought it was a "unique" problem. Very few posts about it..
Thanks for trying to help.
- M
Update... I noticed I had the right-click problem when clicking on a photo thumbnail in the grid. But after a couple of second, the context menu popped up! Coincidentally, I noticed that LR seemed to be making everything way slow. The computer was constantly making disk and processing noise. After a while, right-click a photo thumbnail in the grid became more responsive.
So I thought this "lag time" might be what's causing right-click to not work on the folders. However, even after waiting 15 seconds after the click, the context menu still did not appear.
I still believe there is something going on with LR eating up a lot of the computer's memory or processing time or something else to do with performance. I'm going to do some research about how to make LR faster...
thx,
M
