C# resize image and save
Apr 26, 2018 Apr 26, 2018
Hello!
I look for a sample code that`s resize the image to lower and save it with the 12 (the highest) level quality.
I want the sample to be in .NET C#.
I was searching over the Adobe group and I didn`t find any sample.
Can you help me?
Can you paste me some C# sample?
Thank you in advance
Marcin
Actions and scripting
2.0K
Guide , Apr 26, 2018 Apr 26, 2018
using System;
using System.IO;
using System.Linq;
using System.Text.RegularExpressions;
namespace PSexample
    class Program
        static void Main(string[] args)
            dynamic app = Activator.CreateInstance(Type.GetTypeFromProgID("Photoshop.Application"));
            Regex reg = new Regex(@"(?i)\.(jpg|jpeg)$"); //select jpg files only
            //change folder to suit
                var files = Directory.GetFiles(@"d:/a test", "*.*").Where(path => reg.IsMatch(pat
Adobe
Guide ,
using System;
namespace PSexample
    class Program
            if (app.Documents.Count == 0) return;
            app.Preferences.RulerUnits = 1; //pixels
            //resize to a width of 1000 pixels with constraint
            app.ActiveDocument.ResizeImage(1000 /*width*/, null/*height*/, 300/*resolution*/,5/* ResampleMethod.BICUBICSHARPER*/);
            string saveFile = @"c:/utils/test.jpg";
            dynamic jpgOpts = Activator.CreateInstance(Type.GetTypeFromProgID("Photoshop.JPEGSaveOptions"));
            jpgOpts.embedColorProfile = true;
            jpgOpts.formatOptions = 1 /* FormatOptions.STANDARDBASELINE*/;
            jpgOpts.matte = 1 /*MatteType.NONE*/;
            jpgOpts.quality = 12; //1-12
            app.ActiveDocument.SaveAs(saveFile, jpgOpts, true, 2); //2= lowercase
            app.ActiveDocument.Close(2); /* Close document */
Late binding example.
Ok. Thank you. I really apprieciate it.
But how can I open a jpg image from C# code in Adobe Photoshop.
I would like to:
a) have the filelist array of jpg files in Visual Studio Software
b) open the image file (based on the array of a) ) in Photoshop, resize it and save it to output resized jpg file.
Can you help me with opening jpg file in Photoshop based on C# filelist array ?
Thank you again.
Regards
Marcin
Guide ,
using System;
using System.IO;
using System.Linq;
namespace PSexample
    class Program
                var files = Directory.GetFiles(@"d:/a test", "*.*").Where(path => reg.IsMatch(path)).ToList();
            foreach (string file in files)
                app.open(file);
                string Name = app.ActiveDocument.Name;
                //resize to a width of 300 pixels with constraint
                app.ActiveDocument.ResizeImage(300 /*width*/, null/*height*/, 300/*resolution*/, 5/* ResampleMethod.BICUBICSHARPER*/);
                string saveFile = @"c:/utils/"+ Name;
Thank you I had to change the Identity from "The launching user" to "The interactive user" on the properties pane for Component services/My computer/DCOM Config/Photoshop ActionReference, because I got DCOM error.
But I have one more question to you.
How to keep aspect ration while resizing?
Regards
Marcin
Guide ,
You only supply the width or the height NOT BOTH!
As you see in this case the height has been set to null.
