Hello,
I haven't found this issue in RH help, in the forums here, or
in the Adobe KnowledgeBase.
(This is not the "extra" blank window issue that I found
posts about from 2008/2007.)
We use RH7, and for one browser-based web-enabled
application, are generating the help as WebHelp format, deployed on
IE6. When this app and help are installed on or run on Windows
Vista w/ SP1, the help sometimes does not display. (Click the Help
button on the interface, and a blank page displays.) (Just one
window, not an 'extra'.) When we View Source on the blank page, the
/body/ section is empty! But, if we navigate in Windows Explorer to
the folder on the C: drive where the help is physically stored, and
double-click the startup page, the help displays properly. We're
seeing the same symptoms whether running the app locally (still
launched as a web page) or running remotely with a URL.
The blank page when launched from the app tells us there is a
problem in the way the page is being served up. i.e. something on
the PC's web hosting service isn't handling the WebHelp properly.
Turns out, when running Windows Vista, there is a Windows
option for IIS that must be enabled, and then the WebHelp will
launch correctly from the application. Our developers found this,
and I'd like to pass this along to everyone.
Navigate: Control Panel > Programs and Features > Turn
Windows Features on or off > Internet Information Services ->
World Wide Web Services -> Common HTTP features
Locate "Static Content" and enable this feature.
This isn't a bug in RH or in WebHelp - but definitely an
implementation issue/restriction that help authors and developers
should be aware of. (Windows Vista SP1 w/ IIS enabled)
