Hello! Everything in the folders Lightroom...
After the transfer of the catalog all virtual copies of images were lost. Is it possible to restore them? I have a virtual copy that has processing settings.
All data about VCs is stored in the catalogue. So how have you transferred your catalogue?
I did not tolerate the catalogue itself... I transferred all settings from AppData, partially setting up the catalog from the "Lightroom Settings"... And the image files themselves.
If you imported the photos into a new catalog, then virtual copies will not transfer this way. You need to use the previous catalog.
Thank You! Wish.. I thought the physical copies had to be present somewhere.
You need to copy the catalogue file. It's usually called Lightroom Catalog.lrcat . AppData just has templates and presets.
I have already created a new catalog and transferred 10,000 images, renamed them, reformulated metadata... It's too late to step back..)
Well-tolerated and modules and tags and keywords, in addition to copies and metadata of their personal plug-in.
