quote:
Originally posted by: ke4pym
What is your path? Make sure you're using forward slashes.
ie: d:/java/jdk1.6.0_12/bin/blah/blah/blah
After thinking about it for a minute ... in order for you to do a multi-instance install, you have to have CF enterprise. But, in CF enterprise the Java and JVM sections don't exist. Those are usually found in a CF standard install.
Are you sure your /cfide folder is correct and didn't get copied from a standard install?
What URL do you use to access the administrator?
