1
PLEASE HELP!!! Photoshop Brush scrolls with Vertical Pen input, Brushes with Horizontal. reinstalling, scrapping the preference file, rolling back and re-updating drivers / photoshop, Nothing helps!
Mar 02, 2018 Mar 02, 2018
See the title.  I'm using a Windows 10 Gaming Laptop and a Wacom Intuos Pro 2017 Paper Edition Large, and Photoshop 2018.  Please help me, as PS is unusable to me like this.
10.1K
Community Expert , Apr 27, 2018 Apr 27, 2018
Hello, here is the official fix, without the need to edit the registry : Cannot paint with stylus when zoomed in on image | Windows 10
Adobe
using the brush tool with the Intuos's Pro Pen 2.  Touching the pen to the tablet and dragging in a horizontal direction brushes as intended, but if you move vertical, it grabs the image and shifts it vertically without putting a stroke down.
I have uninstalled, reinstalled, for every version of Photoshop available to CC Subscribers.  I have deleted every preference file, told PS to revert to factory defaults, used old and current drivers for the tablet, and Nothing works.  I have to use a different program for the time being because PS is unusable like this.
Which Wacom driver I use an old one for I have no problem with it but I have the older Pen
JJMack
I can only find 6.3.28-2 on their site as well as the new one.  28-3 is the current one.
6.3.27 seems to be there
JJMack
Must have overlooked it.  I'll go check it, install it, and see if it works if I can locate it.  Will report back with findings
the one from wacom's Site did not work, going to try the one you posted now
No dice.  5 Restarts later that still appears.  One step foreward, 2 steps back it seems.
Mar 03, 2018 Mar 03, 2018
so further experimentation has also yielded to me that the brush tool works properly if you hold right click, and not left.  resetting all tools and all preference files doesn't solve the problem.
Mar 25, 2018 Mar 25, 2018
I have the same problem. I have Wacom Intuos Pro L with Windows 10 64 bit.
Please let let me know when a solution surfaces.
Mar 27, 2018 Mar 27, 2018
I have this problem too. I finally resorted to taping my right click button down on my pen. It sort of worked for about 5 minutes. I recently updated Windows 10, so that might have caused the problem, maybe? If anyone does find a solution, I'd also like to know about it.
Mar 28, 2018 Mar 28, 2018
I found a fix.  Here's what I did:
I called support and was told to deselect the Windows Ink radio box.  I did this, and it did fix the vertical grabbing problem. BUT it also took out the tilt and pressure sensitivity.
Then I found a helpful video:
Wacom tablet responsive issue on Window 10 Fix Ultimate Tutorial
I found out that I had to create a text file in just the right location and type in the proper wording.
I have Windows 10, 64 bit.  I have a Wacom Intuos Pro Large tablet.
I hope this helps!
- bob
If the pen tilt graphic isn't working, all i have to do is open the Wacom Tablet Properties and then go back to Photoshop.  Viola!  Animation back.
Mar 29, 2018 Mar 29, 2018
I'm going to try this in an hour or so, when I have a break from work.
Odd Behaviour however, is that I STILL have Pen Pressure when I turn the checkbox for Windows Ink off.  the issue with the scrolling and work around of right click still behave the same no matter whether or not the box is ticked.
Bonkers behaviour.
Just had a chance to try your suggestion.  Thanks for the input.  It fixed it, but Photoshop had to be restarted.  (Duh, considering settings were modified.)  so once that was done it works, and retains pressure.  No need to right click anymore.  THANK YOU SIR.
Apr 23, 2018 Apr 23, 2018
Hadn't used my tablet in Photoshop for a few months, came back and it was stuck with scrolling the screen unless I clicked the button on the pen on every stroke! I can confirm the fix in the video Bob provided, worked for my Wacom Intuos 2, using the WacomTablet_6.2.0w5.exe driver.
Fix
Create a text file called  PSUserConfig.txt file in location similar to mine C:\Users\YourUserProfile\AppData\Roaming\Adobe\Adobe Photoshop CC 2018\Adobe Photoshop CC 2018 Settings
Type the following and save the text file. Reopen Photoshop.
# Use WinTab
UseSystemStylus 0
Windows 10 Compatible Driver for Intuos 2
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_6.2.0w5.exe
Thanks Bob!
Rich
Been trying to find the solution to the exact same problem all morning. Thanks for your help Bob! That worked perfectly
never mind
no longer working
Friends,
The issue is Windows 10 update 3/22/2018—KB4089848.  The situation is bad, not hopeless; there are two (2) emergency work-arounds.  Regardless which brand of input device one uses, here is the probable answer to this question:
"Every tool acts like Move Tool, and latency: Intuos Pro"
https://forums.adobe.com/thread/2469911
(Scroll to Correct Answer: Wacom Tablets vs. Windows update.  Critical Interface Issue....)
I can't do that.  Thr media I have to reinstall Windows from is pre last creators update and Having an old insider build of windows it won't let me roll back to the specified version.  So this will not fix it for me.  Unless theres some method for me to select what updates windows does after a complete reinstall, But I can't do that for a few months so I'm basically Stuck up creek without a paddle.
Apr 13, 2018 Apr 13, 2018
I had the same problem too and I fixed it. The problem is the latest windows10 update called KB4093112. You can delete the update from windows update history but it will try to re-install the update so u should use this too:
https://support.microsoft.com/en-us/help/3073930/how-to-temporarily-prevent-a-driver-update-from-rei...
Hopefully this can help
Apr 16, 2018 Apr 16, 2018
Okay, so I have an Ugee 1910b monitor with a pen, similar to wacom and I started experiencing the exact same problems that you all are describing. I uninstalled KB4093112 about 4 times because I have Windows 10 home and then I put my wifi on a metered setting so that it wouldn't keep re-installing that update. However, the problem with the pen scrolling up and down and only marking horizontally is back and I don't know what else the problem could be!? Does anyone know if there are any other troublesome updates besides KB4093112 and KB4089848???
I am having the same problem with my Ugee tablet as well. Of course it started up when I was demonstrating the wonderful Adobe Photoshop to a classroom of MIT students! C'mon Adobe, let's get this BASIC tool working again!
