Script Repair After Update
May 02, 2018 May 02, 2018
Hey guys, probably a simple question but I'm a simple man using other people's complex tools and I've run into a snag. I just updated my Photoshop to the latest version and the script I previously had been using to save a jpeg version of the file I'm working on has apparently either broken or I just forgot how it's supposed to be used. I used to have it available under the scripts menu and had a keyboard shortcut attached, but now when I go to use it with File>Scripts>Browse it throws a "Error24: saveJPEG is not a function" error and references line 7. Did something get updated and break the script, or am I doing it wrong? Here's the script, which I think I pulled off someone else's thread here in these forums years ago:
var doc = app.activeDocument;
var docName = doc.name;
docName = docName.match(/(.*)(\.[^\.]+)/) ? docName = docName.match(/(.*)(\.[^\.]+)/):docName = [docName, docName];
var saveName = new File(decodeURI(doc.path)+'/'+docName[1]+'.jpg');
saveJPEG( app.activeDocument, saveName, 10 );
var saveOptions = new JPEGSaveOptions();
saveOptions.embedColorProfile = true;
saveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
saveOptions.matte = MatteType.NONE;
saveOptions.quality = 12;
var docName = doc.name.replace(/\.[^\.]+$/, '');
var jpegName = decodeURI(doc.path) + "/" + docName + ".jpg";
var saveName = new File(jpegName);
doc.saveAs(saveName, saveOptions, true, Extension.LOWERCASE);
//[0] - ??? ?????? ??? ?????; [1] - ??? ??? ?????; [2] - ??? ?????????? ?????
function GetFileName(objDoc)
    var fname = objDoc.name.match(/(.*)(\.[^\.]+)/) ? docName = docName.match(/(.*)(\.[^\.]+)/):docName = [docName, docName];
    return fname;
Actions and scripting
357
Community Expert , May 02, 2018 May 02, 2018
There are some code is missing:
eg like:
function saveJPEG( d, sFile, qty ) {
    //some stuff
    //more stuff
    return;
(This is only an example - not working code)
Update ? From which version to what?
Did you looking for your script also in the correct script folder? For example CC2017 (Windows) in C:\Program Files\Adobe\Adobe Illustrator CC 2017\Presets\de_DE\Skripten
replace (de_DE) with your nation
Adobe
Are you sure the script ever worked? Because the function saveJPEG is completely missing in the code (and there are other mistakes).
Sorry
You know I wish I could say I was sure, but you have me doubting slightly. I am 95% sure though. I have been using a script for years like I said, and this is the only script I have saved in my files, so I'm almost positive that it was this script I used previously. I have looked through my Appdata>Roaming>Adobe folders and been unable to find any other scripts in there at all, but I'm not certain if updating would have deleted anything I had previously or not.
eg like:
    //some stuff
    //more stuff
    return;
Ah that was it! I was looking in the AppData folder rather than the regular Program Files folder, and you were correct it was a different script that I found under the older version. Thank you for pointing me in the right direction to figure out my mistakes!
