Locked
Vertical menu "out of the box" doesn't change active state
May 04, 2018 May 04, 2018
Dear all,
I did a vertical Menu for small devices. I took the example from this forum https://forums.adobe.com/thread/2114736​ and this is the page where the example is shown, you probably might know it http://menu-tap.businesscatalyst.com/index.html.
I have a problem that when I click on a link that points to an anchor point in the same page, just one link stays active. The menu works but it doesn't show the current position.
I'm pretty sure I did all the configuration ok but I'm not sure why is not working, can you please help me? I have double check that al links points to an anchor point.
Here is my example http://www.mi5studio.com/test/index.html
Many thanks in advance
517
LEGEND , May 11, 2018 May 11, 2018
We can’t test your site in depth, because some css-files, which should be uploaded in the „Assets“ folder, aren’t available.
Nevertheless: On actual Safari/Mac the anchor menus are working fine. They change colour after jumping to the intended section.
May 07, 2018 May 07, 2018
Hey grupo b7,
I didn't get the below line you quoted in your thread;
"I have a problem that when I click on a link that points to an anchor point in the same page, just one link stays active. The menu works but it doesn't show the current position."
Also, the link posted by you - http://www.mi5studio.com/test/index.html doesn't open. Can you check and repost it?
Ankush
Dear,
thanks for your response, I gave up and left the project without active link. If you want I can share the project via wetransfer and show you the issue.
Thanks again
May 08, 2018 May 08, 2018
Sure, please do share it with me. Probably we can work it out together and you may resume your project.
Ankush
May 09, 2018 May 09, 2018
Many thanks Ankushr,
Here is a link to download the file. When I deleted some break points images, forms and texts to simplify the file the menu in the smaller breakpoint is working ok... The second breakpoint is not working still.
http://https://we.tl/LEX9TOQ0Ax
many thanks in advanced
May 10, 2018 May 10, 2018
Dear you marked as correct but the problem is still there, the menu in the mid breakpoint still doesn't work.
Thanks in advance.
Hey sorry for that, I was actually trying to access your link and maybe somehow by mistake clicked on "correct answer".
However, I am unable to access your file link, it is not opening up. Can you please check and re-post it?
No worries, here is the link.
WeTransfer
Best
Thanks Gunter, so maybe its a Chrome problem...
