Working with high image volume. Use a photoshop script to create derivative files from the master PSD file in Photoshop. Like to be able to select the PSD files in Bridge and run the Photoshop script from Bridge. Is there a method or function to select thumbnails in Bridge and to run a Photoshop script?
Environment
Bridge CC 2018
Photoshop CC 2018
OSX High Sierra
Hope this helps...
...#target photoshop;
app.bringToFront();
main();
function main(){
//get an array of files from Bridge
var files = GetFilesFromBridge();
//get output folder
outputFolder = Folder.selectDialog("Please select Output folder");
if(outputFolder == null ) return;
//iterate through Bridge files
for(var a in files){
//open each file in turn
app.open(files);
//get the filename without extension
var Name = files.name.replace(/\.[^\.]+$/, '');
//create new filename
var saveFile = File(outputFolder +"/" +Nam
In Bridge use $.evalFile(); to execute your Photoshop script, in your Photoshop script get the selected files.
function getFilesFromBridge(){
var fileList =[];
var bt = new BridgeTalk();
bt.target = "bridge";
bt.body = "var F = photoshop.getBridgeFileListForAutomateCommand();F.toSource();";
bt.onResult = function( inBT ) { fileList = eval( inBT.body ); }
bt.onError = function( inBT ) { fileList = new Array(); }
bt.send(8);
return fileList;
I have basic scripting knowledge. Is there sample Bridge script which calls a photoshop script after a thumbnail is selected in Bridge? I have installed my custom Bridge script and can access it through the menu, but the Photoshop script does not execute when run from bridge.
Once you have selected you files you can use this script to call the Photoshop script.
N.B. The Photoshop script must get the selected files as in the above example.
Amend the scriptName variable to your Photoshop script name.
#target bridge
if( BridgeTalk.appName == "bridge" ) {
runjsx = MenuElement.create("command", "Run Photoshop JSX", "at the end of Tools");
runjsx .onSelect = function () {
function script(){
/*amend with your script name*/
var scriptName = "Your File Name.jsx";
var f = File(app.path + "/presets/scripts/" + scriptName);
$.evalFile(f);
var bt = new BridgeTalk;
bt.target = "photoshop";
bt.body = " ftn = " + script.toSource() + "; ftn();";
bt.send(8);
Thank you for your help SuperMerlin, the code does work. I understand the Photoshop script needs to get the selected files from Bridge. I have placed the function getFilesFromBridge() in the Photoshop script. I am not sure where and how call this function in the Photoshop script. For instance the PS script saves a jpg file with folder selection: Where should I put the function call?
// save to a folder using a dialog box
var theFolder = Folder.selectDialog ("Select Folder");
if (theFolder) {
var myFile = new File( theFolder + "/" + app.activeDocument.name);
app.activeDocument.saveAs(myFile, jpgOptions, true);
//close all documents without saving changes to original
while(documents.length>0){
documents[documents.length-1].close(SaveOptions.DONOTSAVECHANGES);
// jpeg save file options
var jpgOptions = new JPEGSaveOptions();
jpgOptions.embedColorProfile = true;
jpgOptions.alphaChannels = true;
jpgOptions.layers = true;
jpgOptions.spotColors = true;
// get selected files from Bridge
var fileList =[];
bt.send(8);
return fileList;
Hope this helps...
#target photoshop;
app.bringToFront();
main();
function main(){
//get output folder
app.open(files);
var saveFile = File(outputFolder +"/" +Name + ".jpg");
//save file
SaveJPEG(saveFile,8);
//close document
app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
}//end files
//FUNCTIONS
function GetFilesFromBridge() {
var fileList=[];
if ( BridgeTalk.isRunning( "bridge" ) ) {
bt.body = "var theFiles = photoshop.getBridgeFileListForAutomateCommand();theFiles.toSource();";
bt.send(8);
return fileList;
function SaveJPEG(saveFile, jpegQuality){
jpgSaveOptions = new JPEGSaveOptions();
jpgSaveOptions.embedColorProfile = true;
jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
jpgSaveOptions.matte = MatteType.NONE;
jpgSaveOptions.quality = jpegQuality;
activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
Thank you SuperMerlin the script works great! I appreciate your comments on the script, it makes easy to follow the logic.
