Hi there
How exactly have you tried inserting the snippets into the Drop-down?
If you tried the "RoboHelp" way of just plopping things into that frustrating little popup window, you might try a different approach. Insert the snippets directly into the topic as you would want to see them when the drop-down has been clicked. Then select them and cut them to the Windows Clipboard. Then paste that into the frustrating little window. See if that holds.
Another possible thought is that maybe create a sin
...Copy link to clipboard
quote:
Isn't there some kind of code or comment that tells RH, "Leave this alone. Don't mess with this code." If there isn't, there should be.
I'd like to reopen this topic. (Or should I have started a new thread?) I upgraded (long ago) to RoboHelp 8.0.2, and in one project I am having a "snippets in dropdown" problem: When I insert multiple snippets in a row inside a dropdown, only the first snippet stays inside the dropdown. The other snippets (and text that comes after that first snippet) appear outside the dropdown, both in Preview and in compiled help.
I am having this problem in one project but not others. For the life of me I can't figure out why.
Any ideas what could be causing this -- and how to solve it?
One thing I tried: Since I am under the impression that the project's eHlpDhtm.js file controls the behavior of DHTML effects, I tried copying the eHlpDhtm.js file from another project into the project where this problem is occurring. It didn't make any difference.
(I've searched this site and Grainge.org for 15 minutes without finding any reference to this problem.)
Grateful for any suggestions! Thanks.
Hi there
Another possible thought is that maybe create a single cell table and insert them into that. Maybe the additional container code for the table will cause the RoboHelp editor to see things differently? But I'd try the former first.
Cheers... Rick
Rick, I hadn't used the RH way but had done exactly as you described, pasting the text into the frustrating little window.
So I tried your suggestion of creating a single-cell table and pasting them into that. It worked! What a creative idea! I'm really happy now. A thousand thanks!
I had a lot of them to do, so I added the table code directly in the HTML code, after the <DIV> tag:
<table cellspacing="0"><col style="width: 100%;" /><tr><td>
Then I added this right before the </DIV> tag:
</td></tr></table>
Perfect! Thanks again!
