Hello --
I am running 10.13.3 on High Sierra. I have the latest download of Acrobat pro 2017 (desktop software, not the subscription model.) Every time I open it, it closes immediately and I am stumped. I see that there has not been a good solution on the fora which I can find. I really need to get this to work. I tried running it from the guest account and it crashed immediately there too.
I am getting desperate and really need help with this. Any thoughts would be appreciated!
Thank you,
--Ben
When it closes, is there any message?
no. I get the dot as though the app is open and then the dot goes away and the app never really launched.
I have this exact same issue with Acrobat DC on 10.13.3.
It crashes and somewhat freezes my mac. I have to force quit it. It does not close on its own after crash or give a popup.
Hi AttilaB12,
As per the issue description mentioned above, Acrobat is crashing on your mac machine, is that correct?
Please try following troubleshooting steps:
1- Reboot the machine once if you haven't already and check if that helps.
2- Check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
3- If that doesn't work, reset preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again.
4- If issue still persists, try the steps given in the following help document: Troubleshoot Mac OS 10.x system errors, freezes | Adobe software
Also, let us know dot version of Acrobat installed on the machine? You may refer to the steps given in this link on how to check the version: Identify the product and its version for Acrobat and Reader DC
Let us know if you need any help.
Shivam
I am also having this issue. Have not completed trouble-shooting steps. No update is shown as available, and rebooting has no effect. Opens and then closes immediately.
