6 Replies Latest reply on May 12, 2018 3:29 AM by uniqued_tol
    convert to shape
    uniqued_tol Level 2
      Hi scripters;
      I have a lot of objects. I need to change it as follows. (Provided that the contents remain the same;)
      I would be glad if you can help
        • 1. Re: convert to shape
          S Hopkins Adobe Community Professional
          Not too sure what you are looking for here. The convert shape command converts a single item to a different shape. (1) Can be used to convert text frame to a spline item such as rectangle, oval, polygon. (2) Can be used to convert page items (rectangles, spline items, imported page, media items, groups, etc.) to another shape (convert a closed path to an open path, convert rectangle to a rounded rectangle, etc.). Your diagram would indicate combining two items into one as with a group or perhaps embedding one item inside another. Please explain.
          • 2. Re: convert to shape
            uniqued_tol Level 2
            Okay, explain more simply
            • 3. Re: convert to shape
              Sorry about the delay. I think I know what you are looking for now. What you need to do is define a path for the new shape. This takes a little calculation.  The shape created by the following is not exactly yours, but I think you can figure it out from there.
              --select item to modify before running script
              set numPts to 4
              tell application "Adobe InDesign CC 2018"
                set measurement unit of script preferences to points
                set x to item 1 of selection
                set gBounds to geometric bounds of x
                set bhgt to (item 3 of gBounds) - (item 1 of gBounds) --calculate box height
                set bf to bhgt / (numPts * 2) --
                set z to entire path of path 1 of x --path points of original rectangle
                set bx0 to item 1 of item 3 of z --bottom right x point of original
                set by0 to item 2 of item 3 of z--bottom right y point of original
                set edgePts to {{bx0, by0}} --set up list for points on right edge
                repeat with i from 1 to numPts
                set by0 to (by0 - bf)
                set thisPt to {bx0 - bf, by0}
                set end of edgePts to thisPt
                set nxtPt to {bx0, by0}
                set end of edgePts to nxtPt
                end repeat
                set newPath to {item 1 of z, item 2 of z} & edgePts --define the path points
                tell x
                set entire path of path 1 to newPath --create the new shape
                end tell
              end tell
              1 person found this helpful
              • 4. Re: convert to shape
                Level 4
                Just For Fun … But Not For Free!
                "Tatoo" is the last script I wrote!
                The user just selects the "pattern" [s]he created [what [s]he wants! ] and the similar objects [s]he wants to be tattooed! …
                [I'll write later a "batch"version with UI.]
                … and [s]he plays "Tatoo"!
                Even if Tatoo has a global undo, if the user is not satisfied by the result, [s]he can modify the pattern or choose another one:
                … and "Tatoo" again!
                Of course, "Tatoo" loves simple shapes, ID effects and object styles! …
                Best,
                Michel, from FRIdNGE
                2 people found this helpful
                • 5. Re: convert to shape
                  uniqued_tol Level 2
                  I don't know and do not use [as] @S Hopkins.
                  thank you...
                  • 6. Re: convert to shape
                    uniqued_tol Level 2
                    @Michel [FRIdNGE] that's exactly what I want! great job.
